How noisy is your engine?
Old Jun 6, 2006 | 08:02 PM
stubby's Avatar
stubby
Default RE: How noisy is your engine?
Get ear plugs. They will allow you to feel the engine and not worry about noise.
Old Jun 6, 2006 | 08:59 PM
BlackOak's Avatar
BlackOak
Says....
The only thing I hear are people applauding and cheering as I ride by
Old Jun 6, 2006 | 10:54 PM
fl_799's Avatar
fl_799
Use good synthetic oil and it will quiet down. And if it's running stock pipes, you'll hear more engine noise end of story. It's like that on all new bikes not just Harley's. Hell, you should hear the racket my '03 Bonneville T-100 made before I changed the exhaust!
Old Jun 7, 2006 | 11:32 AM
supervette79's Avatar
supervette79
Lets see........a 2 cylinder,air cooled,oil splash,pushrod engine with big valves. That is not engine noise......that audible heaven.
Old Jun 7, 2006 | 03:39 PM
Spectrexx's Avatar
Spectrexx
Like everyone is saying... don't worry about it. It's normal. I stopped using any synth oil and just run Valvoline 20W-50 racing oil. I try out just about every new oil that comes out and the Valvoline is the one I keep going back to. When I use it, the engine's a lot quieter than when using the synthetics. If you change your oil at the recommended intervals (or sooner), there's really no great advantage to the synthetics, except that they empty your wallet faster. I've torn down several engines that have used it and I haven't seen any less wear than on engines that used fossil oil. I don't see the sense in paying more for oil that you still have to change regularly anyway. I change mine every 2500-3000 miles and always use a K&N filter (catches stuff down to 10 microns). Been doing it for a few decades and haven't never had an oil-related problem with any of the engines I've owned or built. If you really want synth for some reason, buy Mobil One (the regular type). It's inexpensive and works just as well as any other oil. My 2 cents....
Old Sep 23, 2007 | 07:33 PM
sargek's Avatar
sargek
ORIGINAL: KBFXDLI
My TC88 clattered a lot with the syn3 oil. So, I switched to Mobil1Vtwin 20w50 and it is much quieter. But still makes some noise. However the annoying clatter is gone. Get some thunderheaders......you'll never hear the valetrain again...
Good to hear someone else say that - I've been listening to my '04 WG clatter away for the last year. Lots of valve train noise, but nothing bad. Amplified by the windshield too, which makes me worry more...It had HD 360 in it when I bought it and when I switched to Syn 3, the clatter got louder. Switched to Amsoil and still a lot of clatter. Am thinking of trying Mobil1. Thanks for confirming my valvetrain clatter is normal...!
Old Sep 23, 2007 | 10:08 PM
JakeSabre's Avatar
JakeSabre
'98 DWG, 55k miles, no clickong, tapping, clanking...nothing, one of the quietest HDs around. I have the EV27 cam with stock pushrods on the front, adjustables in the rear. 20w50 Castrol dino oil. If your bike sounds like a sewing machine, you might want to start tracking downthe clicks and clacks.
Old Sep 23, 2007 | 10:33 PM
DougsDyna's Avatar
DougsDyna
You'll know it right away if you develop an engine problem. I know my 06 tends to chatter more a lower RPMs, under a load.
When cruising, I just hear wind, and a sweet exhaust note.
DougJ
Old Sep 24, 2007 | 12:44 AM
mentor70's Avatar
mentor70
I found my bike to be in the average noise group as far as HDs are concerend.
now that I have a modded engine, its a little louder. It clatters and whines, but its "good" engine noise.
being a auto tech by trade for almost 20 years may give me a tad more torlerance for the HP type noises the come with bigger cams, heavy valve springs and all the other things that make a engine clack and rattle while running.
Old Sep 24, 2007 | 06:29 AM
NightBob's Avatar
NightBob
My 2007 Street Bob runs a bit more quietly now that I've switched to synthetic. But, it was quiet before.
Purrs like a kitten. Big kitten. Big black kitten.
Cohiba_Joe
Oct 26, 2020 08:17 PM
Z
Engine Mechanical Topics
28
Jun 17, 2018 04:33 PM
Nicky Pass
Harley Davidson Videos
27
Apr 22, 2012 01:15 AM
skidmark1964
Jul 14, 2009 10:05 AM
Custom07RKC
Mar 12, 2007 11:20 AM
