Error code P0661
Old Aug 22, 2009 | 06:22 AM
coliseum's Avatar
coliseum
Default Error code P0661
Hi,
I had the bike stored for about 2 months... with the trickle charger connected to it (HD Charger)
Anyway, somehow it seems that a pipe which come out of my Kuryakyn Pro-R Hypercharger came loose and I got the check engine light...
I had 2 error codes come up, one of them was P0661 (cant remember the other) but when I plugged the hose back into its place, the other error code went away but I am still getting P0661 which is Solenoid open...
The only thing I am not sure of, is whether this code has always been there coz I have an after market intake.
I found this online:
New for 2007 and 2008 Harley Davidsons (International models)
So you would likie to enhance your Harley Davidson but the Error codes on the dash are causing you problems? These little units will overcome the problem. There is no modifications required to the bike or harness, or any bulky solenoids being zip tied up behind the throttle body creating a risk of a locked throttle should something move. These units allow a simple plug and play configuration that is 100% reversible at any time.
Intake Solenoid Eliminators
This intake solenoid eliminator will eliminate the dash error codes generated by unplugging your intake solenoid. Simply plug into the wiring harness in place of your air cleaner plug and you are set to go. This will eliminate the P0661 error code (solenoid open). You can now install the air cleaner of your choice.
Old Aug 22, 2009 | 06:25 AM
mikeurig's Avatar
mikeurig
Did you try and clear the codes? And I take it your bike is an international one ?
Old Aug 22, 2009 | 06:56 AM
coliseum's Avatar
coliseum
yes and yes...
Old Aug 22, 2009 | 07:22 AM
dribbledrool's Avatar
dribbledrool
If you got an aftermarket A/C on an international bike then you've had that check engine light since you put the A/C unit on.
If you, like me, can't stand having the Check engine light come on when you start the bike and then go back out when you hit 80km/h... just to come back on when you decelerate under those 80km/h.. then get the Intake Solenoid Eliminator.... I got one for my 2006 Streetbob(even though it says it's for the 07-09 bikes)... works like a charm!!
Old Aug 24, 2009 | 03:38 AM
coliseum's Avatar
coliseum
I actually dont get any codes now unless I check... so the code might have been there for ages, but its bothering me now that I know it there lol
Conga
Apr 7, 2018 11:49 AM
maineultraclassic
Aug 1, 2015 10:09 PM
WNMORE
Jul 18, 2011 11:34 PM
SE120RG
Jul 20, 2009 08:00 AM
scooby doo
May 18, 2009 07:59 PM
