loose rear turn signal mount
Old Aug 22, 2009 | 08:56 AM
jp13's Avatar
jp13
Default loose rear turn signal mount
This may be a dumb question. My rear mount on my turn signal is loose, I unscrew the blinker itself and I can move the mount which rattles while riding.When I put the sissy bar on it stops. I can not figure out how to tighten to the plate. It looks like I should be able to tighten it but do not want to break it,anyone else had this problem?
Old Aug 22, 2009 | 09:11 AM
GeorgeJ's Avatar
GeorgeJ
Thumbs up
When I switched my stock mounts to the mounts that accommodate the quick release hardware for the rack and sissy bar, my new signals stalks would always vibrate loose. They ended up pointing down after an hour ride. Easy fix was to wrap Teflon plumbers tape around the threads then tighten back-up. Haven't loosened up since. - George
ecore
Jul 30, 2019 10:14 AM
Jim Dawson
Touring Parts
Nov 20, 2016 11:51 AM
Peppa1
Jan 24, 2011 11:53 AM
