Rigid Sideplates Install ('06) HELP!
Old Jun 11, 2006 | 09:56 AM
hd_sob's Avatar
hd_sob
Default RE: Rigid Sideplates Install ('06) HELP!
ORIGINAL: Sandhog
Under the bed might work............
[sm=WTFsgign.gif]
Old Jun 11, 2006 | 02:53 PM
dajam_fxdli's Avatar
dajam_fxdli
I did not have any problem doing mine but here is a thought , What about letting the air out of your tire .... then reinflate it... It should work.
Hope this helps,
Good luck...
Missing the big D....[X(]
Old Jun 11, 2006 | 04:09 PM
hd_sob's Avatar
hd_sob
Gave the scissor jack option a try. Sounded like a good idea and LOOKED as though it was gonna work, but didn't. Had the rear wheel completely off the ground and still not enuff clearance to get the damn bolt out. SO, looks like I'm gonna be paying the local stealer $70 to put the sideplates on. THEN, on my way home, I'm gonna stop and have a large 'L' tatooed on my forehead.
Old Jun 11, 2006 | 04:18 PM
jackyl's Avatar
jackyl
try this.use the scissor jack and let the air out of your tire then take the bolt out.try that first before wasting 70 bucks.
Old Jun 11, 2006 | 05:20 PM
Sandhog's Avatar
Sandhog
Yup the air deal might work...
If you had the wheel off the ground and still not enough clearance,the only other thing to do would be remove the lower shock mounts.Damn that seems like a lot of trouble for rigid side plates.Ive owned 4 harleys,rigid mounts on all without running into that trouble.
Old Jun 11, 2006 | 05:36 PM
hd_sob's Avatar
hd_sob
Yeh, I've just about had it with this entire project. What should have taken 15-20 minutes has now pissed me off to the point that its almost worth the 70 bucks to just get it over with. Plus its 100+ degrees outside and that kills my motivation even further.
Thanks anyway for the input, guyz...
STeve
Old Jun 12, 2006 | 02:33 PM
hd_sob's Avatar
hd_sob
ORIGINAL: Sandhog
I've been giving this some thought. Sounds easy enuff. My concern is how difficult it might be to get them back ON. In principle, should go back on just as easy, but that almost never happens. Anybody know for sure?
THANKS!
Old Jun 12, 2006 | 05:27 PM
PsTaN's Avatar
PsTaN
Thread interests me cause sideplates, uprights, and pad are my next project. I just went down and checked my bike. I have a small 5" adjustable wrench and it fits nicely with room to take the bolts out ..... catch is ..... try putting the wrench in from the back of the bike not the side. Just thought this might help ....
PsTaN
Old Jun 12, 2006 | 06:06 PM
hd_sob's Avatar
hd_sob
I can get an open/box end wrench in there easily enuff, the problem is removing the bolt. It is so long that it won't clear the tire when trying to pull it out of the strut.
Old Jun 12, 2006 | 06:53 PM
PsTaN's Avatar
PsTaN
Ahhh ..... makes sense now!!
