tank lift help
Old Aug 29, 2009 | 11:01 AM
wideglide46928's Avatar
wideglide46928
Default tank lift help
ok back in fec did the tank lift(2.5in) man my gas gauge about 1/4 tank off just tired of it can anyone tell me how to adjust the gauge
Old Aug 29, 2009 | 03:55 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
You might consider a partial rear lift to compensate. I just did. Check out my active thread "Wide Glide Tank Lift....". Other than that, I don't know of any adjustment; maybe physically bending the float arm in the tank?
Old Aug 29, 2009 | 04:51 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by PKellyMc
......maybe physically bending the float arm in the tank?....
+ 1 on bending the float arm. Second option is to use your trip odometer. I usually get 300-320 km (186-198 miles) out of a full tank of gas before I have to switch to "RES" and need a refill.
Old Aug 29, 2009 | 05:13 PM
RKLeo's Avatar
RKLeo
Ive been wanting to adjust the gauge as well. How do you get to and bend the float arm?
Old Aug 29, 2009 | 07:22 PM
'09fxdb's Avatar
'09fxdb
Fill your tank....set your odometer...drive 'till you're out of gas...don't drive that far on a tank of gas again...simple
some people gotta start thinking...
Old Aug 29, 2009 | 07:59 PM
Arcane's Avatar
Arcane
If you cannot sit down and figure your gas mileage with out driveling until you are out of gas, then you are not thinking.
Old Aug 29, 2009 | 08:21 PM
RKLeo's Avatar
RKLeo
Ive been doing that since I lited my tank a year ago. It would be nice to have an accurate gauge that didnt trigger my warning light on with 2 gallons still in the tank.
SO...
If anyone knows some details on "bending the float bar"
Please chime in.
Old Aug 29, 2009 | 09:37 PM
jackyl's Avatar
jackyl
ask (mud) he posted it awhile ago, might be hard to find, wish i would of did it then. but i have been wanting to fix mine since i bought the bike, its been jacked since i bought the bike. so i was used to it before i lifted the tank. jackyl
Old Aug 29, 2009 | 11:52 PM
WS6 Formula's Avatar
WS6 Formula
You have to open up the tank under the console and remove the sending unit.
I put a half gallon in then I bent the float rod right by the sending unit (the rod has a "V" shape angle there). I opened that angle up a little, re-installed sending unit and with the bike upright and my weight on it, I recycled the power and run switch and waited for the gauge to settle (there's a delay in the circuit). I had to do this several times to get it right where I wanted it.
Now when the low fuel light comes on I have a half gallon left. Also when my gauge is now reading a half tank and I top it off I usually pump in about 2.2 to 2.3 gallons (4.7 gallon tank)
While your in there you might as well check your internal fuel lines, info here:
https://www.hdforums.com/forum/dyna-...fuel-line.html
Old Aug 30, 2009 | 01:05 PM
FXD2003Rider
Originally Posted by jackyl
.....ask (mud) he posted it awhile ago
Here's what mud posted on this subject(post 5 & 6):
https://www.hdforums.com/forum/dyna-...-question.html
Here you'll find a thread by Mascman on the "tank guts" (pics included):
https://www.hdforums.com/forum/dyna-...nk-guts-3.html
