Bearing adjuster install question
Old Sep 1, 2009 | 08:20 PM
GeorgeJ's Avatar
GeorgeJ
Default Bearing adjuster install question
Alright I got the flame suit on. I'm finally converting my 01 fxd front end to a 06-07and newer front end. Now my old fxd did not have the star nut under the narrow glide top tree. So 2 quick questions.
1- Which way does the star nut go (cone part down or up).
2- The top tree doesn't fit snug like on my old fxd it moves a bit side to side until you tighten down the 1 1/2 nut - is that ok?
Anyway taking pics along the way and hopefully someone clue me in on those 2 things.
Thanks - George
Old Sep 1, 2009 | 09:17 PM
GeorgeJ's Avatar
GeorgeJ
Question
Any one - cone up or down?
Old Sep 1, 2009 | 10:57 PM
kk6pg's Avatar
kk6pg
The star nut fits under the top tree, with the cone facing downward.
Make sure you loosen the top tree, and tighten the nut against the bearings to set fall away.. Install steering nut and tighten to 75 ft/lbs. Tighten tree.
Should get rid of the steering slop you feel.
Old Sep 1, 2009 | 11:01 PM
GeorgeJ's Avatar
GeorgeJ
Thanks - I had it the other way (cone up) because it looked like it snugged into the top tree. I'll flip it and continue as you advised. Pictures tomorrow of this nice upgrade to my 01.
George
Old Sep 1, 2009 | 11:53 PM
WS6 Formula's Avatar
WS6 Formula
That's how the parts catalog and service manual shows it, but when I swapped my Low Rider triple clamps for Wide Glide triple clamps I seem to remember that the upper triple clamp has a cone shape machined into it that would match the cone shape on the nut.
Low Rider's and Wide Glides have angled triple clamps, the lower clamp has the stem mounted into it at an angle and the upper triple clamp self aligns on the cone interface between the nut and clamp.........No?
Old Sep 2, 2009 | 08:08 AM
GeorgeJ's Avatar
GeorgeJ
Oh boy I have one up and one down. Almost seems like the cone facing up into the top tree with the other side (flat) pressing down onto the dust cover of the bearing, looks right. Otherwise if the cone end was pointing down would not lay flat on top of the dust cover.
I hate it when something like this happens. Guys thanks for the input. If anyone has a fxd or bob that they want to peek under the top tree that would be awesome!
George
Old Sep 3, 2009 | 02:57 AM
09DynaMan's Avatar
09DynaMan
my understanding of the "extended shoulder" on the adj nut is so that the load is correctly transferred to the bearing
accordingly it would have to face down to allow for the clearance that is required to ensure this happens
Old Sep 3, 2009 | 09:15 AM
animalmx305's Avatar
animalmx305
Stage II
set it on fire and ride the bandit with no helmet...lol
gleam
Sep 15, 2018 04:58 PM
Tooneyman
Sep 12, 2013 07:35 AM
JT-FXDL
Jul 14, 2011 07:47 PM
DeltaDog
Feb 22, 2010 08:43 AM
EJ48
Oct 9, 2009 11:02 PM
