Steering neck adjuster nut question
Old Feb 20, 2010 | 06:52 PM
DeltaDog's Avatar
DeltaDog
Default Steering neck adjuster nut question
I know this may be a stupid question, but I cant tell in the shop manual which way the adjust nut goes on. I just powder coateds my trees, and on the bottom side of the upper tree, there is a bevel.. on the adjuster nut, there is what appears to be a matching bevel.. So i assume.. the adjust nut screws on bevel up?
Also the PC guy powdered inside that area where the bevel is.. if in fact the adjuster nut does install with the bevel up, is the upper tree supposed to seat completely on the adjust nut.. Mine does not.. there is maybe a 1/32" of a gap there.. So Im thinking I need to sand off the powder in that area??
Thanks, I just dont want to get splattered on I40!!
07 Street Bob
Old Feb 20, 2010 | 08:03 PM
08fxdf43202's Avatar
08fxdf43202
07 Street Bob
It looks like (in my shop manual) the adjusting nut goes on with the 'serrated' edge facing up, so that it is accessible for adjusting after everything is assembled. This would mean that the beveled side of the adjusting nut would be down.
Old Feb 20, 2010 | 09:40 PM
DeltaDog's Avatar
DeltaDog
Thanks man! i appreciate it! I couldnt remember how it was when i removed it for the life of me. Will set it all up tomorrow, and adjust everything.
Thanks again!
Old Feb 21, 2010 | 04:58 AM
jmpancoast's Avatar
jmpancoast
The beveled surface of the adjustment nut goes up so it rests in thye beveled recess of the upper tree. The flat surface of the adjustment nut sits on the washer which sits on the upper neck bearing.
Definitely clean the PC out of the beveled recess in the triple tree so the adjustment nut will apply consistent pressure on the bearings.
Old Feb 22, 2010 | 08:05 AM
DeltaDog's Avatar
DeltaDog
Ok... That's one for bevel up and one for bevel down...
Anyone else???
Thanks bro!
Old Feb 22, 2010 | 08:43 AM
rounder's Avatar
rounder
bevel up.... tree fits around it. with the bevel down, well you'll see.... it is wrong.
gleam
Sep 15, 2018 04:58 PM
ironmike666
Apr 3, 2016 07:22 AM
Tooneyman
Sep 12, 2013 07:35 AM
GeorgeJ
Sep 3, 2009 09:15 AM
choptop
Jul 10, 2008 08:28 PM
