Simple answers to simple questions please
dealer told me about the new race cartridge/download they are using I went with that.
Firstly, right now you aren't looking at increasing the performance at all, just a bettor note right ?
That being the case I'd keep your setup as simple as possible. What you don't want to do is end up with a chain of dependencies that mean you need numerous additional parts, just to get your bike running right.
Down to the options available;
Some guys have had success drilling holes in their stock muffler baffles but I wouldn't recommend it. It is hit and miss (for hackers like me anyway).
So excluding that option the base exhaust mod, I would see as being the Harley Davidson slip-on mufflers. These are still legal in most US states but do have a better and slightly louder note. I haven't heard them so if you can grab a listen to a bike with them it would be worth it. I don't think you need any other mods with these as I believe they don't impact the mixture to any large degree (?) although it is still an option to do so. Happy to hear from anyone with these who can confirm or otherwise.
The next rung up, is the Screamin' Eagle slip-on mufflers. I have these. They will allow air to run through your system more efficiently and so consequently your mixture will have too much air and not enough fuel ( lean). With this option you would just need the Slip-ons and a download.
It is generally accepted that from this modification onwards you need to look at changing your ecu mapping via either a download from HD which is the cheapest option and has set values for a particular specification, or a programmable michanism (SERT (Screamin eagle Race Tune) or Power Commander (PC3) or other similar products) where the mixture values can be changed using a computer and for the optimal, a Dyno tune as well.
If you are only concerned about the engine note, you don't need the high flow air cleaner. When you introduce a high flow air cleaner the mixure will become even leaner and it's best to look at other options than the HD download like the SERT and the PC3. I made the mistake of Screamin' eagle Slip on's , a high flow air filtrer and a HD Download, and my bike is running lean. I am purchasing the PC3 next week and getting the bike dyno tuned, so effectively I wasted my money on the HD download.
I find the Screamin Eagle Slip-ons perfect for volume, in that you can ride relatively quietly, but when you give it a squirt you make a nice, rich rumble, and folks around you know you are there.
Next option up is a full exhaust system replacement. More expensive but better performance. 99.9% of the time a lot louder too. You will generally shake your neigbours windows with these and you definately need to look at a PC3/SERT/other programmable solution. There are combinations of HD and aftermarket exhaust systems and mufflers, but I haven't researched these. Sounds like overkill for what you are after anyway.
My suggestion is:
1.Ask your dealer if he has a bike with the slip-on HD exhasuts and have a listen. I suspect they will be too quiet.
2. Same as above for Screamin eagle slip ons. I think these will be your best option. I think the key point is, if you might want a different exhaust, or any other mods later, it's worth going for the PC3/SERT/ other programmable option now, and not waste time on the HD download. This gives the best flexibility but is slighlty more expensive.
Bit of a rant but I hope that helps...
[quote]ORIGINAL: iwant1
mirage2521, I've been around the proverbial block with this and I have developed my own opinion through articles on this forum, my own bike's performance, and talking to mechanics etc. Having said that, I'm happy to be corrected if I have gotten anything wrong here.
My suggestion is:
I thought I read that the Screaming Eagle II slip ons were no longer avail?
