Bike died while going 50 mph - Need some help
Old Sep 3, 2009 | 09:08 AM
SUPER01's Avatar
SUPER01
Default Bike died while going 50 mph - Need some help
While coming into work this morning, I hit a bump while doing 50 around a curve and the engine died.
Lights were still on and I did not bump the kill switch so I pulled in the clutch and coasted to the roadside, shut the key off and turned it back on, fired right up.
So where do I start looking for a loose wire or something that could cause this problem? I definitely need to fix this, I got lucky there was no traffic by me at the time.
Bike is 2001 Dyna Super Glide stock 88" carb with slip-ons and AN Big Sucker, 27k+ miles.
Old Sep 3, 2009 | 09:34 AM
Gary7's Avatar
Gary7
I had the same thing happen on my 07 Sportster. Engine died going down the Interstate, speedo went to zero. Pulled over, toggled the kill switch, hit the starter button and she fired right up.
The culprit was the main harness under the tank at the connector. Turns out when I had the pullback bars put on at the dealer the tech had pulled on the harness to get enough slack in the wires for the longer bars and loosened the connection. They pulled the tank, reconnected the harness, and it never happened again.
Old Sep 3, 2009 | 10:06 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Same here on a sweeping left turn, banked real nice, holding a line, BUMP, and everything got real quiet real fast. That was three years ago, I've ridden the same road multiple times since and no problems. Rode some nice curvies in N.Y. this summer, no problems. I'm just guessing the mercury switch in the TSSM sensed the lean and bump then tripped and shut down the ignition. 02 FXD (carb)
Old Sep 3, 2009 | 10:48 AM
Phrogman's Avatar
Phrogman
Check your battery cables too. It could be that the combination of lean angle and bump had just enough force to cause a disconnect to a loose battery terminal. Once the bike was upright again, the terminal could then be making contact and allow a start.
Old Sep 3, 2009 | 11:25 AM
SUPER01's Avatar
SUPER01
Never thought about the TSSM shutting things down.
I'll still check things out when I get home, just wanted a few ideas to speed things up.
Thanks guys and any future posters.
Old Sep 3, 2009 | 12:03 PM
Airborne350G's Avatar
Airborne350G
Mine ended up being the battery cables...
Old Sep 3, 2009 | 01:17 PM
BlockHead96's Avatar
BlockHead96
Not only can the above cause this, but if you have the turn signal/brake/running light kit installed, that unit overheats and will shut the bike down. Ask me how I know!
Old Sep 3, 2009 | 01:24 PM
raymond357's Avatar
raymond357
I had loose battery cables too.
Old Sep 3, 2009 | 02:04 PM
SUPER01's Avatar
SUPER01
I'm running the kit for a couple years now. How would it overheat and shut the bike down?
Old Sep 3, 2009 | 04:10 PM
BlockHead96
The unit itself gets pretty damn hot to the touch, for whatever reason. I also have the factory security system, which is tied into the TSSM. I think what is happening is, a signal is sent back to the ECM, from some kind of voltage drop/spike, this confusion is getting crossed up and shuts the engine down. No codes to speak of, lights remain on, turn key off for a few minutes, turn on and start. I chased this tor two months before I got to that harness and took it off to test ride. Has NEVER done it since! To make sure it was that mod, I reinstalled the plug and test ride. It would shut down again. It is now removed for good! The MoCo is aware, but chooses NOT to address! No fun in traffic at highway speeds and that happens. The first time it did, it was WTF just happened! This is a dangerous situation and for the MoCo not to warn of this on the packaging, is a lawsuit waiting to happen. I believe their reasoning for not addressing, is that ignorance is bliss..
I have an 08
