Help with shifter peg
Old Sep 4, 2009 | 11:24 PM
ryderbiker's Avatar
ryderbiker
Default Help with shifter peg
I picked up nice set of knurled pegs, grips, and shifter post. The shifter post is 5/16-18 thread. Does anyone know what the thread is on the stock mid control shifter? It isn't the same as the new shifter post for sure. I still have to figure out how to make it work with two diffierent threads but having having the shifter thread numbers will get me started. Thanks.
Old Sep 4, 2009 | 11:26 PM
09B29's Avatar
09B29
I can find out tomorrow am
Ill get the tap and die set out
Old Sep 5, 2009 | 07:58 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
...Does anyone know what the thread is on the stock mid control shifter...
For the 2003 FXD it is p/n 4017, "BOLT, 5/16-18 x 1 hex. hd. (Grade 5 steel)", the washer is p/n 7041 "LOCKWASHER, 5/16"
Old Sep 5, 2009 | 04:12 PM
ryderbiker's Avatar
ryderbiker
I guess I didn't try hard enough to get the bolt in. I didn't want to mar the threads if it was wrong. Thanks for the info.
Old Sep 5, 2009 | 04:19 PM
FXD2003Rider
You're welcome! Does it fit though?
Old Sep 5, 2009 | 10:12 PM
ryderbiker's Avatar
ryderbiker
No dice. I got a 1 1/4 5/16-18 bolt and was going to cut the head off of it but it doesn't fit the shifter. It fits into the shifter peg nice though. The bolt on the stock shifter peg looks to be a bit finer thread than the 5/16. I may end up drilling the threads out of the shifter and running a buttin head bolt through it. Thanks for the help though.
Old Sep 5, 2009 | 11:38 PM
kk6pg's Avatar
kk6pg
What size bolt came out of it?
If I remember correctly, the bolt I used was a 5/16-24 (SAE).
Old Sep 6, 2009 | 10:49 AM
ryderbiker's Avatar
ryderbiker
That's what I'm asking. The only option here is to modify or change the shifter. I'm not going to tear up the new shifter peg. I will post some pics when I'm done.
Old Sep 6, 2009 | 11:59 AM
FXD2003Rider
Just to be shure: here's a (Dyna 2003) gear shifter diagram + p/n's!
Old Sep 6, 2009 | 03:09 PM
Redbeard's Avatar
Redbeard
That's what I was thinking (which doesn't mean it's the best option).
Where did you get the knurled pegs? I've been looking for a reasonably priced set.
