Oil Change Question
Old Sep 18, 2009 | 08:26 AM
rossperk's Avatar
rossperk
Default Oil Change Question
I bought my 09 FXDC back in Jan. My 1000 mile check was done by Harley. I went in to the dealer the other day to find out what oil to use in a change and how much to put in. They would not tell me. The only answer I got was "if the oil is low just bring it in to us". I just need to know what oil to use and how much.
Simple question I know but I can't seem to get any info from the dealer. My money tree has run dry and I can't take her to the dealer for every oil change.
Old Sep 18, 2009 | 08:54 AM
09B29's Avatar
09B29
Use the Harley Screamin Eagle Synthetic 20-50 in the engine
and
Harley Formula Plus oil in the tranny and primary
Old Sep 18, 2009 | 08:57 AM
red devil's Avatar
red devil
Everything you need to know is in your owner's manual.
Old Sep 18, 2009 | 09:05 AM
tomcat0818's Avatar
tomcat0818
My 08 FXD takes 2.5 quarts engine oil (the 20/50) and 2 quarts of the Formula Plus (1 qt in the tranny plug and a qt in the primary behind the derby cover). That's with an oil filter change. You'll need a torx bit size 27 for the derby cover (at least I do) and you'll probably want a torque wrench with both ft./lbs and newton meters. I usually re-use the o-ring and derby cover seals unless they're nicked or I'm noticing any leakage.
I'd suggest you pick up a shop manual from either the dealer or ebay particularly if you're doing your own maintenance (quite useful for the re-torque measurements on the bolts). Enjoy.
*edit* - noticed someone mentioning the owner's manual. I don't usually check it for measurements as I've got a shop manual, so if you're strapped for cash definitely check it for all the necessary info on oil changes.
Old Sep 18, 2009 | 09:08 AM
vet767's Avatar
vet767
I personally see no advantage to using 12.00 syn oil. Dino has worked for years and never been a problem. It is more about changing it regularily then anything else. Just an opinion and I am sure there will be disagreement. I use 20/50 HD in the crankcase, Formula + in the primary and mobil1 75/90 syn gear oil in the tranny. But the manual 60.00 at HD it will pay for itself.
Old Sep 18, 2009 | 09:09 AM
bigdaddy33's Avatar
bigdaddy33
3 Quarts. I switched to Synthetic 20W50 but you don't need to go synthetic.
Old Sep 18, 2009 | 09:12 AM
bigdaddy33's Avatar
bigdaddy33
If you like to stay with HD oil the Screamin' Eagle Synthetic is $7.95 per quart. More expensive than fossil but not $12/qt.
Old Sep 18, 2009 | 09:43 AM
russell6hp's Avatar
russell6hp
Harley makes and sells "Syn-3" which can go in all three holes. More expensive, but hard to %$*# up.
As far as the dealer not telling you what you need...find another dealer, that guy is a weasel.
Old Sep 18, 2009 | 10:04 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Tomcat has good info except the part about the torque wrench. Most if not all the small fasteners around the engine including primary case, transmission end case and the derby cover are in INCH lbs. not Ft/lbs. An example is "derby cover screws are tightened to 84-108 in. lbs". If you use FT. lbs you'll be up the creek. There are a lot of discussions about what type of oil to use but the viscosity to use is the recommended 20w50.
Old Sep 18, 2009 | 10:17 AM
DGDyna's Avatar
DGDyna
+1 You'll be better off.
