Problem With Backrest. HELP!
Old Sep 20, 2009 | 09:58 PM
02DynaWG's Avatar
02DynaWG
Default Problem With Backrest. HELP!
Alright. I hope that I can describe this well enough but... My girlfriend bought me a new Danny Gray solo seat for my 02 Wide Glide and after waiting 6 weeks I finally got it. When I went to remove the stock backrest and the luggage rack I hit a huge snag. The rear allen bolt won't unscrew. The front one is held on with a nut, but the rear ones have an insert in the fender that is spinning. The back of it just looks like a washer so it's been impossible to get a grip on it with anything. Has anyone ran into this problem or know of any way to fix it?
Old Sep 22, 2009 | 12:19 PM
02DynaWG's Avatar
02DynaWG
BUMP! Someone has to have some ideas. I have tried JB Weld and an epoxy. They don't even slow it down. This is driving me crazy. Got this great new seat and it looks stupid with the backrest and luggage rack still on there. Thanks.
Old Sep 22, 2009 | 12:57 PM
dyna07custom's Avatar
dyna07custom
if it is the zert fitting in the fender you can try to grab the edge of it with small round mouth vice grips or you may have enough room to get a bolt in the back of it tighten with red lock tite and let it sit overnight it might give you enough hold to back out the other bolt. If all else fails you will have to drill the head off the bolt.
Old Sep 22, 2009 | 01:36 PM
INJEKTER's Avatar
INJEKTER
get a flat bladed screw driver in between the flat spinning part and the fender stay, this might give you enough resistance to get it going.
Old Sep 22, 2009 | 02:34 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here is an image of the fender seat nut assambly kit p/n 59768-97 (see attachement).
I would put the bike on the lift and remove the rear shocks in order to create enough clearance between the top of the rear tire and the fender to get a firm grip on the thicker part of the seat nut with a pair of pliers.
FXD2003Rider
Old Sep 24, 2009 | 12:38 PM
02DynaWG's Avatar
02DynaWG
Thanks for all the help. The pics look like if I can remove the taillight and license plate plastic assembly then I should be able to get a grip on it with some vise grips. Need to get a service manual.
byronk
Jan 20, 2018 10:23 AM
jdsmitty10
May 27, 2016 11:39 PM
mamatried01
Oct 7, 2012 02:02 PM
Haulen Ass
Vendor For Sale Classifieds
Sep 23, 2009 08:47 AM
walterwindbag
Dec 23, 2006 09:39 PM
