Oil....
Old Sep 26, 2009 | 01:15 PM
spiritwarrior's Avatar
spiritwarrior
Originally Posted by redrubicon2004
I agree on the HD manual. Very detailed.
As for oil.
Amsoil 20w50 in the engine
Amsiol ATF in the primary
Amsoil 75w140 in the trans
You will read alot about primary leaks, trans seal leaks, and shifter shaft leaks on forums. If you run the same fluid in the trans and primary, it makes it harder to diagnose exactly what it leaking.
Ditto all the above, switched to Amsoil from another syn and never looked back. I ask myself this about folks who say run the same oil in all three holes. Would you put the gear oil in your engine?Then why would you put the engine oil in your tranny?? You need a heavier shear viscosity in the transmission. So much quieter and smoother with the gear oil.
jumpinjoe313
May 10, 2016 03:25 PM
BearKluttz
May 27, 2010 08:46 AM
mebe007
Oil Archive (no new posts)
Feb 11, 2009 05:46 AM
floydpink
May 15, 2007 01:00 PM
NC_Biker
30
May 25, 2006 04:31 PM
