Thanks that gives me more to go on! I was just thinking about the Ford Exploder fiasco back in the late 90's where people were going by tire pressures listed in the manual and not the pressure on the tire. This resulted in many blowouts.
What is needed to be done to swtich the rear tire to a 180?
For the 09 FXDC I think all you need to do is get a 180 from HD or a Pirelli Night Dragon rear.
Wide Tire Kit - DynaŽ Models
Add the wide tire look to your '06-later DynaŽ model. The 180mm rear tire fills out the rear fender to add a menacing look from the back. A simple conversion at your first tire change, the kit...
MSRP Starting at $279.95
Available Online
Stock tires you go by the manual. I go plus one. Not stock you should go by what the tire says. Its a max reading so you can drop it 2 or so pounds. Run a constant average pressure and don't worry. Relax and enjoy the ride.
always go buy vehicle owners manual when finding tire pressures. the pressure on the side of tires is max pressure. the tires on your bike or car are made for numerous different bikes or cars each may require a different pressure depending on weight. if someone says use pressure on side of tires they have no clue what they are talking about. master mechanic for 25 years . hope this helps
