Dyna Tire pressure
Old Oct 9, 2009 | 10:03 AM
rossperk's Avatar
rossperk
Default Dyna Tire pressure
I was looking at my manual the other day and noticed the tire pressure listed was around 36psi for rear and 30psi for front cold when riding one up. Now the tire says 40psi cold. I have been running 38-39psi in rear and 34-35psi in front. I have not had problem with the tires, I have 4,000 miles on my 09 FXDC. I want to do right by my tires. What pressures are you all running? Which is correct, the one in the book, or the one on the tire?
Old Oct 9, 2009 | 10:19 AM
SBRob's Avatar
SBRob
I run 30 front and 37-38 rear cold psi....the front tire is in great shape with no cupping, but the rear tire is at close to 2/32 tread with 7460 miles and will need to be replaced by 8K miles. (next month) I keep a close watch on tire pressures and always check 'em every 3-4 days.
I weigh 195 and ride solo...
Old Oct 9, 2009 | 10:38 AM
RollaMo's Avatar
RollaMo
Tire pressures listed on tires are "usually" MAX pressure with max load.
I would go by the owners manual, and adjust slightly to your conditions if needed.
Old Oct 9, 2009 | 10:46 AM
OhioSkully's Avatar
OhioSkully
I always run my front tire about 2 to 4lbs higher than the book and same with my rear tire.
So iam running around 32 to 34 up front and around 42 in the back all the time. And my tires have lasted longer since doing this and especially make sure they are at this psi when riding two up.
Old Oct 9, 2009 | 10:53 AM
Mole Rat's Avatar
Mole Rat
Now I have the 180 rear and I run 40 lbs in the front I use 36.
Old Oct 9, 2009 | 11:38 AM
Dave's not here's Avatar
Dave's not here
I asked the question to the service guys at the local dealer and he said the same thing.
Old Oct 9, 2009 | 11:39 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
31 front 40 rear no problemo
Old Oct 9, 2009 | 12:46 PM
dyna07custom's Avatar
dyna07custom
31 front 39 rear got 9k out of rear front has 14 k still fine
Old Oct 9, 2009 | 12:50 PM
OldFenderGuy's Avatar
OldFenderGuy
I weigh in at 185 pounds (seldom ride 2-up), and on my Harley's I run 35 front, 40 rear...
Old Oct 10, 2009 | 08:39 AM
rossperk's Avatar
rossperk
Thanks that gives me more to go on! I was just thinking about the Ford Exploder fiasco back in the late 90's where people were going by tire pressures listed in the manual and not the pressure on the tire. This resulted in many blowouts.
What is needed to be done to swtich the rear tire to a 180?
