Comfy two up cruising???
Old Oct 12, 2009 | 01:46 PM
SC-Longhair's Avatar
SC-Longhair
Heck of an idea Bill.
The more I look at your design, I can't help but think it won't necessarily move your passenger back. They will still be constrained by the placement of the sideplates. Your design will allow a passenger to lean back a bit, but I'd think it may cause the mid-section to protrude further.
I could be way off on my thinking. I'd say give it a shot and see what happens. The worst is it doesn't work and back to the drawing board.
EDIT: Try modifying a different setup...like the Kuryakyn Plug-n-Play. It is a backrest that does not use sideplates. it merely bolts to the fender. Now, there is a concept to start with.
You'd be free to position the backrest so it may actually move the passenger back.
Old Oct 12, 2009 | 03:05 PM
billjoat's Avatar
billjoat
Good point, SC-Longhair. Enough so that I went outside to check it out. With the fat touring seat, the top of the sideplate is about 1.5" below the top of the seat at the very rear corner. Since my wife's butt isn't a bubblebutt(she'd kill me if she read all this) and since I'm trying to get her mid-section away from me, I feel I can put her right on the edge of the seat and pick up the needed 3-5". Even if I can't move her back any distance, I can still lean her upper body back a few and since we're compressed; my back to her belly, this will stretch her out a smidge and flatten that tummy.
Old Oct 12, 2009 | 03:12 PM
SC-Longhair
I wasn't sure if the sideplate cleared the seat or not. Too lazy to peek outside at mine.
One other thing... you may have to compensate for the bends by making the sissybar a bit longer or the pad will undoubtedly be lower on your passenger's back and may cause issues.
Each bend in your sissybar will cause the overall height to be shorter.
Old Oct 12, 2009 | 05:09 PM
billjoat's Avatar
billjoat
Good point. I did that plus one better. Called my wife at work to see if she would like it a bit taller as well. Sure she did. Here's what I've made this afternoon. She's already home, sat up there, and now we have PLENTY of room.
One more thing. Since I still have to weld the pad support on the bar, I think I'll wait until tomorrow and see if the local HD shop has a little larger and possibly wider back rest in stock. Even more comfort for my wife. If she feels she has to go along, might as well make her(and me) as comfy as possible.
Attached Thumbnails Comfy two up cruising???-000_0127.jpg   Comfy two up cruising???-000_0128.jpg   Comfy two up cruising???-000_0129.jpg   Comfy two up cruising???-000_0130.jpg
Old Oct 12, 2009 | 05:16 PM
1953riderforlife's Avatar
1953riderforlife
Kuryakyn makes an extender for the tour pack. Not sure whether they made one for the backrest or not but may want to check.
Old Oct 13, 2009 | 05:08 AM
billjoat's Avatar
billjoat
This really opens up a wide range of options. Today, after checking out the backrest pads(may even use a wider touring style) I think I may make yet another one ...now just a little shorter. I've also thought of the possibility of a backrest for myself when I rally alone(most of the time..so far). I'll base all the backrests off the detachable mounts. If I don't use the rear rack; it requires the backrest to be drilled and tapped, I can probably get away with just the outward pressure of the backrest arms to hold it in. 5/8 solid rod, a little heat, a few bends, a little paint(I'm a gloss black Rustoleum man) and a new rest is just around the corner. Hard to beat the price, fun to do, quality is definitely a 10 footer(looks good from 10 feet) and a wide range of options.
Old Oct 13, 2009 | 06:39 AM
Notgrownup's Avatar
Notgrownup
I had a 05 Sportster and fabed my own side plates and had them chromed for about $45.00. Took the originals and put them on a piece of cardboard traced what i thought would be a good position to have the new ones. cut 10 gauge steel and welded receiver bracket on them... sanded and cleaned them up. Had them chromed. Voila.
Old Oct 16, 2009 | 04:28 AM
billjoat's Avatar
billjoat
Got it finished for a ride this weekend. Put the new pad on it for my wife's back and it fits her great. Seems a little high so I'll probably make another one and out of 3/4" this time for a little beefier feel.
Attached Thumbnails Comfy two up cruising???-000_0131.jpg   Comfy two up cruising???-000_0132.jpg   Comfy two up cruising???-000_0133.jpg
Old Oct 16, 2009 | 06:19 AM
Notgrownup's Avatar
Notgrownup
That looks pretty good...As long as it's solid use it...Sometimes when you stop and think of it...These things are not that hard to make...
Old Oct 16, 2009 | 07:33 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Great when someone gets creative to solve a problem. Nice work; "If mama ain't happy, .....)
