Starter grinding problem
Old Oct 11, 2009 | 07:36 PM
bwanas's Avatar
bwanas
Stage IV
Default Starter grinding problem
Can anyone suggest a cause / solution to my occassional starter grinding problem? I have a 2007 dyna. Get an occassional loud grinding when starting. Replaced the battery and keep charged on a trickle charger. Can get it to start only if I give it an extra boost with a battery charger. Wont start w/o it even with the fresh battery. Some threads seem to point to a starter clutch problem ? Of course, the waranty just ended. Thanks !!
Old Oct 11, 2009 | 08:46 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Disconnect the battery and check the cables to the starter, make sure the connections are clean and not paint between the lug and frame on the grounds, then clean your battery connections and snug them done real good. Remember connect the battery ground after the positive is connected.
Old Oct 12, 2009 | 07:59 PM
bwanas's Avatar
bwanas
Stage IV
Thanks. I'll check that. I had a bad cable years ago on a RoadKing, but that resulted in no starter turnover at all. This starter is certainly turning, but the solenoid seems to not be throwing far enough.
Old Oct 12, 2009 | 08:25 PM
Evil Stepdad's Avatar
Evil Stepdad
I had the same problem with my starter on my 08 Fat Bob. It started out intermittent but gradually got more frequent and was harder to start each time. The dealer replaced the starter, and I haven't had any problems since. Here's what the dealer's service notes said: "Tech confirmed grinding out of starter. Pulled primary cover and checked pinion gears, all looked good with no debris in primary fluid or case. Performed current draw test and every time starter began to grind and amps jumped above 300 with the highest reading at 365. Typical values are 160-200. If amp reading is over 250 new starter is required. Tech R and R starter and problem was resolved".
Old Oct 13, 2009 | 05:21 AM
bwanas's Avatar
bwanas
Stage IV
Thanks Evil. A verbatim description of this finding is going to be attached to my bike when it hits the dealer service bay this weekend ! Very helpful. I'll update the forum with the results.
Old Oct 13, 2009 | 09:27 AM
seniorsuperglideE8
Some service department will act on what the customer has already decided on whats wrong. Personnaly I would let them diagnose the problem, then ask the question to see how the problem was diagnosed. Amp draw test would be on my mind when it's time to pick up your bike. The answer from Evil sounds right.
Old Oct 22, 2009 | 09:21 PM
bwanas's Avatar
bwanas
Stage IV
Verdict is in...bad starter. Thanks to all for your help
thirsty
EVO
14
May 16, 2019 11:03 AM
ronk74
Shovelhead
11
Jun 15, 2016 08:38 PM
Rescuediver1982
EVO
Jul 28, 2015 08:39 PM
pjb
EVO
May 8, 2012 07:15 AM
Mar 26, 2012 06:54 PM
