Old 02-18-2015, 10:49 AM
How-Tos on this Topic
Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
Print Wikipost
  #4591
Old 04-09-2014, 09:39 AM
Fxdb1988's Avatar
Fxdb1988
Fxdb1988 is offline
Default My bike after winter upgrades
Se211 cams, wild1 tbars, led head light, V&H pro pipe, hd stage 1 intake.
Attached Thumbnails Thug Style / Club Style Dyna pic's-image.jpg
  #4592
Old 04-09-2014, 09:53 AM
SLV's Avatar
SLV
SLV is offline
Looks good! I love my Pro Pipe, but I noticed that they hang lower on some bike. I wonder why. Does your drag? Mine never has, but it looks like it's mounted higher for some reason.
I do have 13" shocks. Maybe that's the difference.
  #4593
Old 04-09-2014, 01:01 PM
b2inUT's Avatar
b2inUT
b2inUT is offline
You may have noticed how low mine was with my Burly Slammers (10.5"). It's right in line with the swing arm now with my Progressive 970s (12.5").
Aren't the stock shocks 11"?
I haven't dragged it since the shock change... And I've taken some turns that would have previously ripped my pipe clean off of the bike...
  #4594
Old 04-09-2014, 01:24 PM
SLV's Avatar
SLV
SLV is offline
Stock shocks for the Street Bob are claimed to be 12" but I never actually measured them.
  #4595
Old 04-09-2014, 02:11 PM
SLV's Avatar
SLV
SLV is offline
Bright bright sunny day. 70 degrees in Savannah.
  #4596
Old 04-09-2014, 02:37 PM
DynaKid94's Avatar
DynaKid94
DynaKid94 is offline
Looking good SLV! At some point I want to do the skateboard wheel shifter/brake pedal, but with white to match my paint. First though I need to do something with the handling. Want to go with a 19" front wheel, not liking how the narrow 21" wide glide wheel catches EVERY line in the freeway. Also thinking of having my grandfather pick me up a true track stabilizer while he's in Laughlin for the river run. Worth the $$$ or should I be looking at something else?
  #4597
Old 04-09-2014, 02:41 PM
monster715's Avatar
monster715
monster715 is offline
Check out the sputhe stabilizer. I'm sure they're pretty similar, I have the sputhe and the quality is great and you can really feel it tighten the bike up
  #4598
Old 04-09-2014, 02:44 PM
SLV's Avatar
SLV
SLV is offline
Sputhe and True-Track are very similar in function. One is aluminum and one is steel.
Suspension should be first though. Quality shocks and a front spring upgrade go a long way toward a great handling Dyna.
  #4599
Old 04-09-2014, 02:50 PM
DynaKid94's Avatar
DynaKid94
Thanks guys, will definitely have a look at both. Bike has progressives on the back right now, but they look lower than stock to me. Been keeping my eye out for a cheap(ish) set of stock FXDXT shocks to lift the back up a bit. Want to hold off on doing anything to the front end-want to switch to dual disk 39mm front end eventually from the wide glide. I've got plenty of plans, but I'm a bit lacking in the $$$ department haha
  #4600
Old 04-09-2014, 03:18 PM
Guest
Guest
Posts: n/a
Do you always ride on the sidewalk? lol
Quick Reply: Thug Style / Club Style Dyna pic's
