Should Throttle Be Loose
Old Jul 4, 2006 | 08:30 PM
kaduku's Avatar
kaduku
Default Should Throttle Be Loose
I just had my 1K service on my Bob, and the mechanic made my throttle very loose and smoothe (like butter), he said that it should be like this. He didn't really explained why. Has anyone done this and reasons why????
Old Jul 4, 2006 | 08:45 PM
sprintrps's Avatar
sprintrps
Default RE: Should Throttle Be Loose
It is that way so you don't inadvertantly give it gas when making a right turn.
Old Jul 4, 2006 | 09:01 PM
ROADTRAIN's Avatar
ROADTRAIN
Kaduku
What do you mean by loose,
Too much freeplay as in movement at rest.
Easey to twist as in no resistance when riding.
The only problem with the easy to twist is that when you hit a bump the throttle moves and the bike jerks. But you will get use to it.
Old Jul 4, 2006 | 10:05 PM
kaduku's Avatar
kaduku
Yes, easy to twist, no resistance. I took it for a test ride, and it was actually very nice!
Old Jul 4, 2006 | 10:30 PM
ROADTRAIN's Avatar
ROADTRAIN
That's good also easy on the wrist on long rides.
Old Jul 5, 2006 | 12:28 AM
kaduku's Avatar
kaduku
Yes, It was especially nice on the freeway.
Old Jul 5, 2006 | 02:42 PM
superdog48's Avatar
superdog48
The mechanic probably but some oil in the cables to make it loose. This has to be done every no and then.
Old Jul 5, 2006 | 02:57 PM
kaduku's Avatar
kaduku
He actually did lube it. He also said that if I wanted it tighten back, just turn that ****. I will ride with it like this for a little while just to see if I get used to it.
twisted47
Aug 28, 2014 08:06 AM
blusmbl
Mar 15, 2011 06:18 PM
sstlcm08
Jan 23, 2011 12:20 PM
utexasrider
May 29, 2007 05:09 PM
swomack
Oct 20, 2006 10:41 AM
