hard time finding neutral.....why????
Old Oct 27, 2009 | 10:37 PM
JohnnyBravo's Avatar
JohnnyBravo
Default hard time finding neutral.....why????
when i roll up on a light i prefer to put it in neutral and take my hands of the bars.....lately i have been having a hard time finding neutral....it seems stuck and the force needed to move the shift lever causes it to fly by neutral and right into 2nd.....i then fiddle back and forth until i get frustrated and say f-it......if i turn off the motor it goes right into neutral......any ideas why this is happening????
Old Oct 27, 2009 | 10:41 PM
DrSmaggs's Avatar
DrSmaggs
Is this a new touchiness on a familiar bike?
I noticed all HDs have a different feel to easily finding the N.
I never have trouble on my dyna, yet on a Street Glide I was on I had to throttle slightly or roll it a little.
Old Oct 27, 2009 | 11:02 PM
Jonn2002's Avatar
Jonn2002
Adjust your clutch maybe?
Old Oct 27, 2009 | 11:05 PM
jeff.georgalas's Avatar
jeff.georgalas
Get to know your bike
Old Oct 27, 2009 | 11:42 PM
archergodwin's Avatar
archergodwin
Adjust your clutch, and put thicker oil in your tranny. I run Mobil-1 75/140.... smooth shifts... neutral is no problem.... it may help.
Old Oct 28, 2009 | 03:20 AM
jmpancoast's Avatar
jmpancoast
If the bike has been serviced just prior to you experiencing this difficulty finding neutral, pull the derby cover and check your fluid level.
Too much fluid can cause this symptom.
Old Oct 28, 2009 | 08:19 AM
Streets of Fire's Avatar
Streets of Fire
+1 on this advise... Same thing happened to me this spring.
Old Oct 28, 2009 | 08:25 AM
Nightking's Avatar
Nightking
If it feels as though it kind of clunks going into first , then you need to adjust your clutch .If you barely let the clutch lever out in first and it starts to walk, adjust the clutch. Trouble finding nuetral is always a symptom of clutch being out of adjustment.
Old Oct 28, 2009 | 08:29 AM
Phrogman's Avatar
Phrogman
+1 on adjusting the clutch. I just crossed the 9k mark and I've needed to adjust mine for about the last 500 miles.
It wouldn't hurt to check for overfull primary, but I'm assuming that this is a new occurrence on an older service since you mentioned that it's just been recently happening.
Old Oct 28, 2009 | 09:20 AM
sniper77's Avatar
sniper77
I've had this problem with a custom (Baker 5 speed)that I put a new clutch in so it may have nothing to do with the clutch or the fluid level of the primary.
The symptoms are exactly as you describe (both before and after the clutch change) so I'm still at a loss unless there is wear in the shifting forks which is the next thing I'm thinking of checking.
