08/09 fxd
Old Oct 28, 2009 | 07:51 PM
Wireguided's Avatar
Wireguided
Default 08/09 fxd
Has anyone put a 180 on their stock 10 spoke rear rim yet?
If so how does it fit ? And are you happy with it.
Old Oct 28, 2009 | 08:22 PM
2007fxdc's Avatar
2007fxdc
Mine are 07 but I have one on mine. It fits fine and rides good. I think bberck has one on his as well.
Old Oct 28, 2009 | 09:07 PM
Wireguided's Avatar
Wireguided
yeah that should be the same rim.
4.5 i think ..
Well thats good to hear maybe ill get a 180 this time around.
Old Oct 28, 2009 | 10:06 PM
yso191's Avatar
yso191
I have one on my '08 and it works great. I love the look and if anything the handling improved. Not going back.
Steve
Old Oct 28, 2009 | 10:27 PM
bberck's Avatar
bberck
Have one on mine and have been happy with it so far (about 5K).
If dont get the kit make sure your signal wires are out of the way. I got mine twice before I got them out of the way good enough.
Just put the matching SE tire on the front and happy with it so far. It sticks in the corners much better than the stock tire with 16K on it LOL
Old Oct 29, 2009 | 08:23 AM
2007fxdc's Avatar
2007fxdc
That's a good point. If you go through a dealer, they are likely to try and make you buy the entire "wide tire kit". Well, the kit is just a couple of brackets that retain your signal wires under the fender. That's something you can do on your own if you want. My dealer would not sell me the tire unless I bought the kit. So, I got my indy to order the tire (cheaper than I could from the dealer by the way) and install it for me. I have the detachable hardware and signal relocation kit installed on mine which uses a bit more wire than stock so my wires were already being pulled out of the way. I've had 0 issues with wires being rubbed. On the other hand, I had the wires come out of the clip on one side of the fender when the bike was almost new and got rubbed in two by the stock tire.
Old Oct 29, 2009 | 09:57 PM
Wireguided's Avatar
Wireguided
I already moved my wiring when i did the FLHR rear light bar..
The bracket kit is a major ripoff.. (wide tire kit)
Im suprized quite a few people actually buy it..
Thanks for the info guys ..
JeffJA
May 8, 2013 02:36 PM
trackadaptor
Aug 5, 2011 05:34 PM
DPM
Oct 5, 2009 08:33 AM
chieffieldeng
Sep 21, 2008 06:39 PM
bob37
Aug 25, 2008 04:26 PM
