Gauges
Old Oct 29, 2009 | 10:06 PM
Just-a-Guy's Avatar
Just-a-Guy
Default Gauges
I would appreciate it if anyone could offer any comments or suggestions on this. As a lifelong gearhead, I like to know what's going on with my engine. I like gauges. Obviously there is no need for a water temp gauge on e Dyna, but I would like to have oil pressure, oil temp, altmeter and tach. I would like to rig something up so I mount them on the t-bars, either on the risers or on the bar, behind the bars...that is, in the space basically between the bars and the tank. The attached pic may help some.
FWIW, I also would like to have an outside ambient air temp gauge (thermometer), small clock and possibly a compass. (Yes, I said I was a gearhead...make that nerd gearhead.)
I see a lot of miscellaneous gauges etc, but I don't see any kind of overall solution or setup. I was thinking of getting one of the HD tach/speedo mounts and taking it to a machine shop to modify for the additional gauges, then powder coat.
Any ideas?
TIA!
Mark
Old Oct 29, 2009 | 11:18 PM
Baeseman1's Avatar
Baeseman1
Did you check out the ThunderMax yet? There is a bunch-of-stuff built into that thing you'll like.
http://www.thunder-max.com/Products/...eedometer.aspx
Here's a thread I started on it a while back
https://www.hdforums.com/forum/dyna-...eedometer.html
Old Oct 30, 2009 | 02:45 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Here's something I did with FORMOTION instruments. Seemed silly to mount delicate instruments on the most vibration-prone part of a bike (bars), so I bent the mounts a little and bracketed the speedo with 'em.
Old Oct 30, 2009 | 09:41 AM
fixxr's Avatar
fixxr
Dakota Digital just came out with a new Direct plug in model that will fit right in your bike!It has a lot of the stuff your looking for and did I say it plugs right into your stock wire harness=E-Z The part# MCL-3204
Old Oct 30, 2009 | 09:50 AM
Lorance66's Avatar
Lorance66
probably an iPhone app for that
Old Oct 30, 2009 | 03:55 PM
Just-a-Guy's Avatar
Just-a-Guy
Thanks for the replies, fellas. Those digital things look cool... but I prolly should have said, I kinda prefer analog. (My VCR blinked "12:00" for 20 years, until VCR's became totally obsolete. I stopped watching movies then.)
PKelly, that's a partial solution, but it's also easy, so I may go with something like that at least for the clock and thermo. My speedo mounts on the bars ('06 model didn't have it on the tank), so it's a challenge. But I have an Accutronix bracket that has similar mounting points, so I can do that...
Thanks.
mark
Old Oct 31, 2009 | 10:24 PM
WS6 Formula's Avatar
WS6 Formula
Any ideas?
TIA!
Mark
Best thing to do is photoshop your ideas then make it happen with a custom bracket, that you can easily make with clamps and/or a sheet metal plate.
Old Oct 31, 2009 | 11:58 PM
yso191's Avatar
yso191
Love the gauges Patrick! Excellent setup.
Steve
murrayliving
Mar 26, 2014 06:10 PM
cromagnon
Nov 24, 2010 12:36 PM
Kicks
Oct 18, 2009 04:51 AM
cropsure
Jul 8, 2009 02:22 AM
tUt!
Sep 29, 2008 03:11 PM
