What can i gain with 4 extra cubes?
Old Nov 2, 2009 | 08:46 PM
cjm8806's Avatar
cjm8806
Default What can i gain with 4 extra cubes?
I now have 103" motor SE 10.5-1 Pistons, if i were to bore it to a 107" or even a 110", How much would i gain and would it be worth it.
I have cams, Headwork, SE 50mm throttle body,and SS roller rockers.
Thinking about doing it this winter just curious if it would be worth it or not.
Old Nov 2, 2009 | 09:59 PM
cjm8806's Avatar
cjm8806
No Inputs? or Comments?
Old Nov 2, 2009 | 10:23 PM
JaronB's Avatar
JaronB
Here ask this guy!! Member JCK is also doing this build, but isn't complete yet.
https://www.hdforums.com/forum/dyna-...hat-to-do.html
Old Nov 2, 2009 | 11:20 PM
SURFOR Chop's Avatar
SURFOR Chop
What is your goal ...?
You're sayin' that what you got now is inadequate??? What kind of dyno numbers is your bike putting out now?
I guess it's a sickness ... you'll probably end up like forum moderator "Mud" who ended up with 121" ... LoL ...
I'm not sure he's satisfied ... he could be goin' up to 131 next for all I know!
[Just yankin' your chain ... if you're reading this Mud!]
R/
'Chop
Old Nov 3, 2009 | 02:23 AM
sniper77's Avatar
sniper77
The old saying is: all things being equal, there's no replacement for displacement.
Realistically you wouldn't see any performance gains except on paper, maybe. If you just want to spend some cash and have some fun try a nitrous system of a supercharger, either will make tons more power than any internal work you could do from this point.
Old Nov 3, 2009 | 06:45 AM
redrubicon2004's Avatar
redrubicon2004
If you are like me and enjoy tearing down your own engine, I would say go for it! If you are paying to have it done, the difference may not be that big of a payoff for the money. I am sure you would notice a difference, just not that much.
Check into a Axtell 117" kit. Its a big bore kit but the cases would need to be bored out to accept the new jugs.
Forgot to mention. Depending on how much more displacement you go with, you may need to consider a different cam as well to meet the needs of the new engine. The cam you currently have may work on the 103 but it may not work well on a 107,110,or 117 Just something to consider.
Old Nov 3, 2009 | 07:30 AM
C-Cat's Avatar
C-Cat
1 to 1.1 hp extra per cube, and slightly more on the tq.
Old Nov 3, 2009 | 07:48 PM
cjm8806's Avatar
cjm8806
I have woods TW-408-6 Cams (Hi-Lift)
I think they would be fine for a bigger motor.
Thanks for the input guys, im kinda feeling the itch to tear into it again since i cant ride it in the winter, ha it gets me every year!
Old Nov 3, 2009 | 08:58 PM
paul s's Avatar
paul s
Do the 30T pulley, you won't regret it.
Old Nov 3, 2009 | 09:12 PM
jackyl's Avatar
jackyl
you will get a empty wallet. jackyl
