2010 Wide Glide forward controls
Old Nov 21, 2009 | 06:29 PM
t37's Avatar
t37
Default 2010 Wide Glide forward controls
Has anybody heard of a way to move back the foot controls without making a huge project out of it, I am 5'8" tall and I way 185 I can reach the controls with my legs bent a little, but it still feels like I am reaching for the rear brake peddle. Maybe it is just a feeling I will have to get used to. Any input will be much appriciated.
Old Nov 21, 2009 | 06:44 PM
manofsteele2003's Avatar
manofsteele2003
Maybe you can change out the pedal pad for a different style, might gain a 1/2 inch or so.
Old Nov 21, 2009 | 06:47 PM
t37's Avatar
t37
Someone else suggested floor boards.
Old Nov 21, 2009 | 07:06 PM
KAUFMANSM's Avatar
KAUFMANSM
I'm 5'6" and some one suggested Kuryakan extenders for the foot pegs. I'm going to try them the give you 1 1/4 "
Old Nov 21, 2009 | 07:15 PM
ghostrider69's Avatar
ghostrider69
I've never been a fan of floorboards. There is no easy bolt on kit. So I built my own brackets.
Old Nov 21, 2009 | 07:24 PM
t37's Avatar
t37
Ghostrider, so you moved your pegs back?
Old Nov 21, 2009 | 08:48 PM
ghostrider69
I moved both mounts back 1 1/4", which is as far as you can go because of the outer primary cover. The only major mod which really wasn't major and only took about 20 minutes was to cut the threaded rod from the end of the brake rod then cut 1 1/4" from the rear of the brake rod and weld the threaded rod back on so that the brake lever would be in the right position. The shift rod did not have to be altered because you can remove the shifter and reposition it where you need it.
Old Nov 22, 2009 | 12:19 AM
SURFOR Chop's Avatar
SURFOR Chop
You might also try the 'stirrups' or heel rests ... give your foot a little more stability and take some of the stress off your legs ....
Ghostrider ... ingenious setup ... well done (was kind of wondering about the brake rod) ....
R/
'Chop
Old Nov 22, 2009 | 06:32 PM
Le Vizir's Avatar
Le Vizir
Wow..
Very good idea Ghostrider !!!
And nice work too..!
Do you have a picture of the left side with the shifter..?
Thank's a lot
Old Nov 22, 2009 | 06:38 PM
ghostrider69
Yeah, it's not the best angle because the bike is on the stand. If you would like a better shot I can try and get one tomorrow. It may not look like it but the entire peg assembly is moved back 1 1/4".
dirtdobber
Oct 28, 2011 10:08 PM
dirtdobber
Oct 28, 2011 08:14 AM
Zinje
Aug 16, 2011 10:12 PM
grimreaper169
General Topics/Tech Tips
Mar 24, 2008 10:48 PM
Garemlin
Nov 25, 2007 08:08 PM
