Whats this plug for?
Old Nov 21, 2009 | 09:05 PM
rattlebones's Avatar
rattlebones
Default Whats this plug for?
I just got a 2002 FXD. I changed the transmission oil and the primary oil. I was having trouble getting to what I thought was the drain plug for the engine oil. Turns out I had the wrong plug. So now I was just wondering if anyone can tell me what the plug is for (That I thought was engine oil) that is an Allen head right behind where the kickstand mounts? It faces towards the front of the bike.
Old Nov 21, 2009 | 09:09 PM
meatball64's Avatar
meatball64
Thats for the radiator. no its also crankcase.
Old Nov 22, 2009 | 09:30 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Default pipe plug on transmission housing
Originally Posted by rattlebones
....So now I was just wondering if anyone can tell me what the plug is for (That I thought was engine oil) that is an Allen head right behind where the kickstand mounts? It faces towards the front of the bike....
As I understand well, you're talking about the "pipe plug" (see attachment). Like you, I'm anxious to know what it is for as well!
FXD2003Rider
Old Nov 22, 2009 | 12:28 PM
Derv's Avatar
Derv
Got to confess I was tryng to take this one out to drain the oil before I discovered there was an easier drain plug to get to. That one sits behind a frame crossmember and can be a P in the A to get out.
Not sure what it's purpose is but I suspect it's from an original design for an earlier engine, and to save costs on re-tooling to delete it HD have just left it there and made another in a more accessible place. If you do take it out you'll need to thread seal it when you put it back - according to to manual
Derv
Old Nov 22, 2009 | 02:39 PM
rattlebones
Thanks all. I will just leave it alone.
Old Nov 22, 2009 | 05:56 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Welcome to the board, just leave that plug alone.
Old Feb 23, 2010 | 03:41 PM
FXD2003Rider
FXD2003Rider
I found the answer over here; it's for the oil temp gauge sender unit:
Originally Posted by rocknrod
If this is in an 08:
a. Most guys were successfule at NAPA. I have been to the Home Depot adapter area also. No joy.
Bring the Plug with you and the Sender with you. NAPA is the place.
b. No teflon tape. I used Loctite white.
c. Sender in the pan is more accurate of the overall oil temp.
I have pics in image-shack but it's not playing well right now. When it does I will post them (im gonna move em all to phot-bucket I think)
Someone else has some really good pics however that I saved. Maybe they will come along.
That aint no joke.
Dont forget to change the color of the light bulb to match:
Take your tank off, easy. The fuel connection is a quick release and there is no cross-over on the 08 model tank.
PhatBoyHigh
Nov 25, 2015 11:11 AM
Ring
Oil Archive (no new posts)
Apr 22, 2010 07:27 PM
HDSAE60
Aug 12, 2009 08:58 PM
VrodAJ
May 19, 2007 09:22 AM
cutacroshorty
Jun 25, 2006 01:49 AM
