Pipe removal advice
Old Nov 27, 2009 | 01:02 AM
Quickie's Avatar
Quickie
Default Pipe removal advice
I want to remove the bassoni pipes on my 06 St Bob to have them recoated this winter. I have never taken out the sensors on each pipe before. I was just looking for some direction on how to remove them propery. Any tips would be apprieciated.
Old Nov 27, 2009 | 05:07 AM
maddghost's Avatar
maddghost
Spray some loose nut or liquid wrench on there and let it work it's way in a plenty. don't force too much and twist anything. If they are really stuck then try tightening them just a bit,then go back to loosening. At worse once the pipes are off you could heat the sensor bung with a plumber's torch and that should get them free..........unless you try loosening them and they just come out easy, who knows?!
Old Nov 27, 2009 | 11:29 AM
rdondes's Avatar
rdondes
It is easiest when you remove the pipes from the bike first. Then proceed as maddghost indicates. Upon re-installation, make sure to coat the threads of the oxygen sensors with Permatex anti-seize lubricant (silver stuff). Do not get the anti-seize lubricant on the sensor end of the oxygen sensors. By the use of anti-seize lubricant, you can get the things out years later with no problem.
Old Nov 27, 2009 | 11:32 AM
Scout's Avatar
Scout
Large pipe wrench......
Couldn't help it.
Old Nov 27, 2009 | 11:53 AM
r00k's Avatar
r00k
+1 and when you reinstall the O2 sensor be generous with the anti-seize.
Mikeduke108
Jul 24, 2014 08:27 PM
lanceropolis
Aug 3, 2013 06:58 AM
Jessie
Sep 7, 2011 07:08 AM
whateva
Jun 15, 2007 08:16 PM
pfd161
Exhaust System Topics
Apr 28, 2007 01:20 PM
