Bob with tfi?
Old Jul 13, 2006 | 02:04 AM
stbob's Avatar
stbob
Default Bob with tfi?
Hey im a new guy and was looking to get some help cause everybody i know has a bike with a carb.
Does anyone have a bob with tfi. Im looking to change exhaust and was wondering if the 02 sensors would be a problem.
also my bike misses every now and then was wondering if any one else had this problem, maybe the tfi?? I am still trying to get the
bike to run well because the dealer never tuned the tfi. I discovered on my own that it was just slapped on, all still at factory settings.
I cant give you all a pic but it has modified se2 mufflers and se2 air cleaner and some nice powdercoat work
Old Jul 13, 2006 | 07:02 AM
man4mopar's Avatar
man4mopar
Default RE: Bob with tfi?
I know absolutely nothing about a techlusion. But you may want to check this site, they seem to be all TFI users.
http://www.dobeckperformance.com/for...iew.asp?fid=34
The TFI say's it works with the factory O2 sensors but they do not go into detail how they work with them. Least not in my short research into it. I assume if it works with the O2 sensors they do not eleminate them like the Power Comander.Meaning you will most likely need pipes with bungs to install the O2 sesnors. The options are growing quickly in exhaust for the 06 dynas.
Happy trails.
Old Jul 13, 2006 | 01:04 PM
stbobber's Avatar
stbobber
I have a Bob with V&H pipes and a TFI. Works fine. You will need a TFi or PC111 or Fuelpak if you modify your exhaust.
Old Jul 13, 2006 | 02:19 PM
Whiffleboy's Avatar
Whiffleboy
I have a Bob with the DFO (same thing). I also have the HD Download and BCT baffles now, so, I can't help you with your settings. However, tweaking it is simple. You just adjust the four settings until you're happy. It won't be fine tuned like a PCIII or SERT will allow, but, it will get you in the ballpark and will eliminate the lean condition of your bike. Better yet, call George at Dobeck and he'll give you some settings.
He recommended cutting the third setting down a bit if you're running a download with your setup.
Whiff
braap_27
Apr 20, 2018 03:49 PM
Rubline
Nov 25, 2014 04:12 PM
wilk3173
Apr 28, 2014 10:38 PM
King_O_Road
Exhaust System Topics
Sep 21, 2008 11:43 PM
jca_54
Nov 20, 2006 11:02 PM
