Install steering damper
Old Dec 7, 2009 | 06:19 PM
JRK5892's Avatar
JRK5892
hell ya! i got one in my shop waitiing for me to make some 49mm clamps for it... i am using a rocket damper that i have adjusted to let out all the way... it is pretty big so i am going to go from my down tubes to my forks... i am stoked to get it rolling! best part is, paid 5 bucks at a swap meet!
Old Dec 7, 2009 | 07:05 PM
Lama's Avatar
Lama
I believe the Pingle Harley Destoyer 49mm fork clamp would work, I will call them to get a part number.
Need the frame clamp and damper.
Old Dec 7, 2009 | 07:11 PM
MZBuckeye's Avatar
MZBuckeye
Can you elaborate on how it installs on your 05?
Old Dec 8, 2009 | 04:00 AM
Derv's Avatar
Derv
If you're installing a damper for looks then go for it, but if you're genuinely trying to use it to sort out an existing handling problem then you need to look at what's causing that problem in the first place. Steering dampers come from race bikes that have a steep rake angle and are thus unstable under power in a straight line as the weight is transferred from front to rear.
While fitting one to your Harley could stop a tank slapper occuring, if you're getting wobbles to the degree that you tnink you need a damper then the root cause needs to be treated - not the effect!
Cheers
Derv
Old Dec 8, 2009 | 07:48 AM
rounder's Avatar
rounder
You got to remember, they also improve straight line tracking. They will increase confidence in cornering situations and grooves and big bumps too. Gives a different feel to the front. Just makes the bike feel more stable. Stability brings confidence and thus the end user can smile more as he blasts further into turns and such. In the end he probably did not need the stabilizer, but having it made the ride more enjoyable. And it looks cool too.
Old Dec 8, 2009 | 08:23 AM
CountryPunk's Avatar
CountryPunk
You can buy those steering dampers under a different name from McMaster-Carr for about a quarter of the price..
Old Dec 8, 2009 | 09:47 AM
JRK5892's Avatar
JRK5892
what are they listed under? I buy from them almost daily!
Old Dec 8, 2009 | 09:49 AM
JRK5892's Avatar
JRK5892
found them! http://www.mcmaster.com/#adjustable-dampers/=4udaou
anyone know what sizes we would need? i want to stock these!!!
Old Feb 13, 2011 | 01:17 AM
748*2Risk's Avatar
748*2Risk
Yup, it's a two year old thread. Anyway for those that fabed there own kit, what did you use for a frame clamp?
Cruiseman
Harley Davidson Videos
Mar 8, 2013 07:17 AM
95custmz
Jan 14, 2012 11:03 AM
zzmellio
Jul 19, 2007 05:46 PM
HDF Tech
Sep 4, 2005 06:44 PM
