another 30 tooth thread
Old Dec 15, 2009 | 02:18 PM
jarhead45's Avatar
jarhead45
Default another 30 tooth thread
Soooo ... looking at the 30 tooth sprocket. 06 FXD .... no motor work. My buds cruise at 88 mph. period. thats just the way we/they roll. At what rpm am I gonna be at cruising at 88 mph? 90 if it is easier for you to check. I like to run at about 32-3500 rpm around town. just looking for some technical feedback.
Old Dec 15, 2009 | 03:52 PM
JRK5892's Avatar
JRK5892
if it was warmer i would take her out for a rip! sorry man!
Old Dec 15, 2009 | 04:09 PM
dpriest's Avatar
dpriest
i think its time for a 7 speed tranny.lol. i know i'm always looking for an extra gear.
Old Dec 15, 2009 | 04:25 PM
db252's Avatar
db252
Are you looking at doing a 'sprocket' change or a 'pulley change' just to be clear? Also, to figure out your rpm at speed (any speed), use the link below. It allows you to fill in your specs about tire size, gear ratio, primary drive ratio, and final drive ratio. I looked to see if they had an 06 spec and they don't so you'll have to input the info. It is very informative.
http://gearingcommander.com/
Old Dec 15, 2009 | 05:07 PM
jarhead45's Avatar
jarhead45
its the front pulley. common change it looks like. Just I cant afford to give up too much top end. I need to be able to cruise at 90 to stay with the pack. Would need to stay below 4K rpm with that 30 tooth pulley in order to not cream my motor over the long haul. Then there is that occasional instance in which we need to be somewhere and the pack is cruising at well over 100+. Hmmm , maybe I need a cam instead of the pulley. mmmm
Old Dec 15, 2009 | 05:12 PM
db252's Avatar
db252
Just making sure, you do know that when you change that sprocket you will no longer have a compensator, right? Don't know if that is of any concern to you.
Old Dec 15, 2009 | 05:43 PM
jarhead45's Avatar
jarhead45
I dont think 06's have the compensators. Not that it matters if I did change it. Kinda looking at cams now that I have more or less answered my own question on top end. But hey, if someone gets back to me and says they do 100 mph and only doing 35-3700 rpm I might do it. Right now it kinda looks like woods tw6-6 cams with a 4* advance gear.
Old Dec 15, 2009 | 05:49 PM
paul s's Avatar
paul s
http://bigboyzheadporting.com/Gearratio.htm Looks like about 3750@90
Old Dec 15, 2009 | 06:21 PM
hddan502's Avatar
hddan502
Bud, you will have no problem doing 90. I still can still peg the speedo(2007 SB), if not to hot out. The biggest difference I noticed is around town I am not having to shift up/down as often, and she does take off a little quicker. P.S have no tach so can't tell you the rpm.
jeffbetrollin
Sep 24, 2015 07:04 AM
HDF Tech
Jun 19, 2011 05:50 PM
cannedham1
Feb 17, 2010 06:12 PM
dope_man_21
Aug 2, 2009 04:37 PM
buckmc
Jun 4, 2008 11:34 AM
