please help
Old Dec 19, 2009 | 11:32 AM
79lowrider's Avatar
79lowrider
Question please help
ok i have an 04 dyna lowrider 88ci fuel injected with stage 1 and a V&H fuel pak with V&H straightshots, question is i cannot get this thing to stop running so rich and its really starting to get annoying, at low speeds you cannot just cruise smooth you have to be on the throttle or it does the jerk thing also when riding and commin to a stop pull clutch in and bike will almost die the idle comes down sooo low but as you sit at the light it will slowly raise back up and clean itself out also at an idle when you start to twist the throttle it chokes so always have to rev it up a lil a couple times before taking off.. anyway i have changed plugs cleaned the intake air filter etc. dont know what else to do also have put in 50 different codes in the fuel pak all which are slightly different but none that fixes this problem had this problem before the fuel pak was hopein the fuelpak would fix this prob however it hasnt.. please help
Thanks guys
Paul
Old Dec 19, 2009 | 11:40 AM
stevelonewolf's Avatar
stevelonewolf
Does V&H have one certain set of codes for that set up? I've actually had them make a set just for certain set ups. Have you checked your intake seals for leaks? Just curious..
Old Dec 19, 2009 | 12:05 PM
79lowrider's Avatar
79lowrider
intake seals...... hhmmmm now why didnt i think of that? so how do i check them? lol
Old Dec 19, 2009 | 09:55 PM
stevelonewolf
Get some brake cleaner/carb cleaner. Start your bike. Manually keep it at idle?(1000rpm) and spray lightly but firmly(lol)in the direction of the intake seals(fr/re)with out overspraying in to the air cleaner. If the idle changes either way? they're taost.
Cory Epperson
Jul 25, 2018 09:09 AM
ironfist_001
May 2, 2016 06:46 PM
AFDynaRider
Jul 14, 2015 02:51 PM
jett78
Exhaust System Topics
Mar 7, 2009 08:45 PM
96 Ultra
Sep 8, 2008 02:14 PM
