Need help with front end
Old Dec 20, 2009 | 07:58 AM
8541hog's Avatar
8541hog
Agreed, some are simple swaps, some are not. You have to do the research, which is why he is here. You make some very valid points, I just did not want him to think it was lost if catalogs or HD said it can't be done.
Old Dec 20, 2009 | 10:22 AM
roofer's Avatar
roofer
I put deuce triple trees on my 2003 fxdl with softail standard lower legs that I powder coated, the main thing you will have to do is cut or grind off the stop on your frame because the lower tree on the deuce hits it and you will have to do some grinding on the stops on the trees so you can get your turning radious my sig pic is with the deuce trees and the trees do have I think 3 degrees in them
Old Dec 20, 2009 | 12:42 PM
rounder's Avatar
rounder
exactly what I was going to point out.... To the OP J&P has a nice variety of triple trees for a wideglide that look real good, don't cost any more than stock trees would and have stops for your current setup. Check out their selection at their website. You can get black, chrome, polished, with or without rake. The deuce lowers have a specific axle for them and of course as stated before, your wheel will need to be change to a wide glide wheel or you will need to get a spacer for your front brake disc, and axle spacers to adapt the wheel to the front end. Also need to think about a fender as well.
Old Dec 20, 2009 | 01:21 PM
ackman1968's Avatar
ackman1968
Agreed, you could find trees similar to the Deuce trees that are made for the Dyna frame. It's a lot of grinding to make Softail trees fit the Dyna, I wouldn't have performed all the work if there were aftermarket FL trees available but sadly there aren't any.
Old Dec 20, 2009 | 10:23 PM
FastHarley's Avatar
FastHarley
Former Sponsor
You should not use later model (1986 (?) ~ Current FL trees as they have a 4 1/2* rake in them and the forks are behind the stem. Yes they would work but these trees would make your Dyna handle like a real slug. Do the math by downloading my Rake & Trail calculator prior to doing the doing.
I have one set left of a set of billet aluminum trees made for a custom bike using 41mm trees & a wide glide rim (6.32") from flange to flange. You use a internal fork stop (I have them) and the steering stem is a blind hole so nothing shows up top. They can be chomed but they are polished currently. There is no mounting brackets like a FL or Softail Heritage. Steering stem is 2.23" I think but I would need to look. This will put your trail around 4.75" with a stock wheel but you would need to figure it out for yourself.
Old Dec 21, 2009 | 01:05 AM
SURFOR Chop's Avatar
SURFOR Chop
Howard:
Rick was referring to FLST vice FLHR front end ... as you correctly point out, the late-style Road King front end will not work, but the Heritage front end will.
R/
'Chop
Old Dec 21, 2009 | 10:36 PM
ackman1968's Avatar
ackman1968
Originally Posted by SURFOR Chop
Howard:
R/
'Chop
Exactly! I should have been more specific in my post. Boy if you think the FLST front end didn't turn much before the mods could you imagine a Road king setup on a dyna? You would have to notch the tank to get it to turn! It's the goofiest looking setup with the neck out front leading the fork tubes.
Old Dec 22, 2009 | 06:46 AM
fryejs's Avatar
fryejs
check out my post....cross a fatboy and dyna and get...I have pictures of cutting the stops on the neck and grinding the stops on the trees. the stop on the neck i used a hack saw-i dont recommend it. hahaha
the above posts about the grinding are correct tho.
Old Dec 24, 2009 | 02:36 PM
lewistg's Avatar
lewistg
generally the softail forks are longer than the fxd. i put a softail front end on my fxd,but i had to install a 5 degree triple tree to offset the length of the forks. other than that it will work just fine. if the prices are right just go and buy you a 5 degree raked triple tree. i got mine on ebay for less than $100. Good luck.
Old Aug 18, 2010 | 11:13 AM
Panhead Jeff's Avatar
Panhead Jeff
3rd Gear
I ride a 50 Panhead with an original Wishbone frame. I want to replace the basically useless front drum brake with a single disc front end. Anyone have any words of wisdom? My front end has had the lower legs shaved so I had to adapt a shorty fender to it. The chrome on the tubes is VERY tired to the point of having a lot of tiny pits in it so the seals in the lower legs leak no matter what. The Chrome on my trees isn't BAD, but I think that with new upper and lower legs it'd be rather obvious that the trees were "old" chrome.
Thanks...
04Fxdl87
Mar 30, 2018 08:11 AM
Anty_daniel1
Oct 3, 2016 10:50 PM
Cricket11
Jul 25, 2011 10:26 AM
scottm1220
Jan 23, 2009 04:43 PM
Jacket4256
Sep 7, 2008 07:03 PM
