Primary Chain Adjuster Problem?? HELP
Old Dec 30, 2009 | 07:51 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
No timing issues with the motor. Just be sure to follow the shop manual to disassemble the clutch plates, you won`t have to remove the clutch assembly from the primary.
Old Dec 30, 2009 | 10:07 AM
Dyna3B0B's Avatar
Dyna3B0B
I will take apart the clutch plates today after I get off work and see what I find. All the spockets look good so hopefully the clutch does too.
Old Jan 1, 2010 | 07:32 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The engine isn't "timed " to the clutch, the primary chain on the engine/clutch is there to transmit the power from the engine to the drive components. Similar to the main sprocket to the axle sprocket on a bicycle.
Old Jan 2, 2010 | 04:00 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by Dyna3B0B
...I found the part that I needed online and removed the bad adjuster.....
I hope you ordered the right p/n 39929-06A....check out this post & pics by mud from this thread Finally, Good News - Inner Primary Bearing :
Originally Posted by mud
slick, that extra bit of metal is simply an install device.
as opposed to tyWrapping for install.
these pix are 2006 HD FXDI..............
in all three pictures
.......the tensioner on top is part # 39929-06A
.......original equipment also shown 39929-06
above, and the two pix below,
you see the -06A component is considerably beefed up.
Both pix above, you can clearly see that the original skinny toothed base section is distorted
disallowing full and positive engagement with the toothed wedge.
below, you see they not only beefed up the base piece,
they also reconfigured the wedge,
changing to 5 teeth at each end instead of teeth continuous from end to end.
Old Jan 2, 2010 | 05:10 AM
hawkdsl's Avatar
hawkdsl
You would think the MoCo would have found this problem in that design before putting it on the street.. Sheesh.
My 02 DWG has one of those HB 125 hydraulic tensioner. The OP can get one in that wedge style too: http://www.sohotbikes.com/wedge.html
Dyna3B0B, don't feel bad, its no biggie. Sh*t happens. My Buddy's drain plug backed out once on a ride, and didn't know it until the same thing happed to him. He was lucky he wasn't killed with all the primary oil all over the back tire. I would definitely take the clutch plates out, and clean them. Its a real easy job, and good piece of mind.
Old Jan 2, 2010 | 07:23 PM
Dyna3B0B's Avatar
Dyna3B0B
The Wedge that I found in my primary was the wedge with more than five teeth. I haven't ordered the part yet because I have to wait until I get paid Friday but it's good to known that there are two different parts. I will make sure to check out the part before I leave the shop to ensure it is the right part.
OPDSam30
Oct 5, 2024 02:28 PM
semiret
Nov 19, 2014 08:15 PM
steveh326
Jan 27, 2008 05:48 PM
Soarer
Sep 11, 2006 12:40 AM
gtrman
May 25, 2006 06:27 PM
