Cable Change
Old Jan 4, 2010 | 12:53 PM
NOZEM's Avatar
NOZEM
Default Cable Change
I am changing the cables (Throttle/Idle) on my 05 FXDCI, is there any way around removing the tank? Thanks
Old Jan 4, 2010 | 12:59 PM
r00k's Avatar
r00k
I'd say just pull the tank, even if it's possible to run the cables with out removing it, it would make life waaaayyyyy easier.
Old Jan 4, 2010 | 01:00 PM
rounder's Avatar
rounder
Yup, just lift it up from the rear. Did not remove my tank to change my cables. will want to prop up front to remove front cable guide from frame. Slip a screwdriver behind it and it will pop out of the frame hole.
Old Jan 4, 2010 | 01:06 PM
NOZEM's Avatar
NOZEM
I'll try that Rounder. There doesn't seem a lot room though, the vacuum hose is holding it down I think.. I unbolted the tank yesterday to see if I could slide it back...
Old Jan 4, 2010 | 02:49 PM
rounder's Avatar
rounder
Pull the hose from the petcock/connector. Also pull the fuel line. I can stick a 3" wide roll of duct tape under my tank. That's my 'go to' tank holder when it's raised. I do have a carb, so it's much easier for me in regards to the fuel line and such.
Old Jan 4, 2010 | 03:07 PM
NOZEM's Avatar
NOZEM
Mine is fuel injected...
Old Jan 4, 2010 | 03:36 PM
rounder's Avatar
rounder
yeah, disconnect the fuel line and vacuum hose.
SJ12DS
Carburetor Related
Jul 10, 2016 09:48 AM
TylerBoehm
Jun 7, 2014 06:55 AM
cmosentine
Mar 12, 2013 09:10 PM
roofer
Nov 15, 2007 11:32 AM
KBES BAGGER
Jan 28, 2006 01:20 PM
