need sissy bar help!
Old Jul 19, 2006 | 05:24 AM
TOMMAY's Avatar
TOMMAY
Default RE: need sissy bar help!
ORIGINAL: Harleygirl81
Glad I found someone talking about the sissy bar! My husband has the Street Bob also! Has anyone tried putting those side plates on that???????????? Oh my god!!!!!!!!!!!!! The bolt that holds the signal light on goes through the inside of the fender and when you "try" to take it out, it hits the tire. We finally figured a way to get it out, (not without of grunting and groaning and swearing). We had to let some air out of the tire. Got the damn sideplate put on and they gave us the wrong one!!!!!!!!!!!!!!!! We had to take it back off! The new ones should be arriving in a couple days and any suggestions on how to put those side plates on an easier way would be much appreciated!
I can help you on this, it's late and i've been out partying for a while, so if this is not clear, pm me tomorrow and i'll do better. What you need to do is cut a slot from the bottom of the side plate to the opening to the rear bolthole so you can drop the side plate down into position by by loosening the rear bolt just a bit.The best tool for for loosening the bolt is a ratcheting combination wrench which you can buy almost any where now,half inch if I remember correctly. What you want is a slot like the one for the wiring,only big enough for the bolt to slide thru. You'll need a three corner file to start your cut then a hacksaw to finish your cut with. This way way can remove the front bolt,use a pick or small screwdriver to push spacer out of the way,position the front of the sideplate,reattach the front bolt loosely,then pivot the side plate down into position over the wiring and rear bolt,tighten everything up a bit,do the same thing on the other side ,then cinch every up good and tight and you're good to go. It's not a quick detach,but it's not all that slow either.
[IMG]local://upfiles/8936/6ED2A8647CBC4196B20C748FA3AE209D.jpg[/IMG]
Old Jul 19, 2006 | 09:58 AM
johnpiech's Avatar
johnpiech
On the Bob, if you don't like the sideplates - you can get the mount that goes under the seat, and has the pad right on it. If you go with the side plates, you can switch out any number of sissy bars.
Old Jul 21, 2006 | 09:04 PM
sapperw5's Avatar
sapperw5
which is the mount that goea under the seat? where is it from? sounds like itwouldbe beter andmore movable. thanks
Old Jul 21, 2006 | 09:36 PM
jmbear328's Avatar
jmbear328
I got the ridid mounted sideplates on my 06 Superglide and I had it all installed in under 30 minutes. I also didnt have to remove the rear shock bolts. I wanted the quick detachable at first but dealer didnt have it in stock and I decided to go with the rigid,...which was good now since I like the looks of it enough that no need for me to remove it. The sissy bar is a Med-Low from H-D and the backrest is a top stiched medalion.
John
Old Jul 22, 2006 | 10:22 AM
subculture08's Avatar
subculture08
ORIGINAL: sapperw5
the lady is starting to complain on the long trips. looks like i need to get the sissy bar now instead of later.
I had the low, but she was not diggin it so I change to the tall and she loves it.
Old Jun 30, 2007 | 09:14 AM
SCREAMING EAGLE's Avatar
SCREAMING EAGLE
Hello, i see you have taken off the battery band and replaced the holes with what ?
Thanks Rick
[IMG]local://upfiles/35788/3A5099B04007491DA4C02A224CD390DA.jpg[/IMG]
Slim G
Dec 31, 2014 07:50 AM
Chucklesgolf
General Topics/Tech Tips
Aug 26, 2014 07:48 PM
brandonk25
Dec 3, 2012 12:26 PM
Lakeville Street Bob
Jun 7, 2009 11:51 AM
Maxdmax
Jul 29, 2008 06:54 AM
