Sissy bar install question???
Old Nov 9, 2012 | 09:52 AM
brandonk25's Avatar
brandonk25
Default Sissy bar install question???
I am wanting to get a 16" bar from Bowman Welding off of ebay. The stock sissy bar was removed from my bike when I bought it and there are no spacers between the strut and the fender. Will I need to install spacers on the front/back/both between the the sideplates and fender during install??
Also, has anyone notched the Bowman sissy bars?
Thanks for the help.
Old Nov 24, 2012 | 07:46 PM
brandonk25's Avatar
brandonk25
Went ahead and got the sissy bar ordered. They were giving 10% off for Black Friday Weekend!! Can't beat that. Any help on the above???????
Old Nov 25, 2012 | 06:22 AM
Tepidy's Avatar
Tepidy
If its a detach sissybar you need to buy the harley quick release kit. If it is permanant than you have to buy the harley spacer kit
Old Nov 25, 2012 | 09:50 AM
djack's Avatar
djack
I have a bowman bar on my bob, nice piece. are the spacers you're talking about the ones on that strip that mount from inside the fender? but yea you'll need them thats what ties the struts,fender an bar all together, the rear actually needs to e longer with the sissy bar
Old Nov 25, 2012 | 10:10 AM
Hogpro's Avatar
Hogpro
Former Sponsor
The side plates are what you need. The go between the fender and the strut if you want the solid mount version. No spacers necessary. If you want quick detach you need the quick detach mounting points and different side plates.
Old Nov 26, 2012 | 09:28 PM
brandonk25's Avatar
brandonk25
The spacers or washers I am thinking about are going to go between the rigid sideplate of the bowman sissy bar and the fender. I only think I may need them so the side plate doesn't sit directly against the fender and scratch the crap out of it. Thought maybe I needed to put a plastic washer or something in there.
Old Nov 26, 2012 | 09:54 PM
crimson13's Avatar
crimson13
The bowman bar goes just like the oem bar did no spacers if your bike did not have them I lined my bowman bar with felt like material to go against the fender , Name:  13040062029491.jpg
Old Nov 26, 2012 | 10:09 PM
kateean2's Avatar
kateean2
I love this thread already.
Old Dec 3, 2012 | 12:26 PM
brandonk25's Avatar
brandonk25
Got the bar put on. It was kind of a pain in the ***. Removed lower shock bolts and jacked the bike up. Had to jerry rig a lift system. Secured front end with straps to garage ceiling and then jacked the bike up with a Ford Expedition wheel jack. It actually fit under the bike well and worked perfect. The bolts came out easy after that.
I did put a piece of pad on the bar to go between it and the fender. Hope it keeps it from scratching. I didn't want to notch the entire back bolt hole, so I just cut out a small section to slip over the tail light wiring so I wouldn't have to mess with the wiring.
I have a custom license plate bracket the attaches to the rear strut bolt also, and after adding the sissy bar the bolts were to short to catch the tail light. Had to go buy some 3" bolts and cut about 1/4" off of them to make it work.
Another issue I had was that the bar was welded onto the side plate slightly lower than it probably should be. The bar sat directly on top of the the strut cover and put downward pressure on it. That caused the rear strut cover bolt hole to be slightly misaligned with the strut hole. The little tab on the front of the tail light did not want to stay in the hole because the cover and strut didn't line up.
I should have taken some pics of it but I forgot. Not a big deal, the tail light just doesn't sit quite as flush as it did before.
rjjj629
Aug 3, 2015 05:43 AM
Chucklesgolf
General Topics/Tech Tips
Aug 26, 2014 07:48 PM
MikeSz
Sep 9, 2011 09:15 AM
Native American
Dec 21, 2008 02:43 PM
08HSTC
Jul 16, 2008 12:12 PM
