need sissy bar help!
Old Jul 18, 2006 | 10:46 PM
sapperw5's Avatar
sapperw5
Default need sissy bar help!
the lady is starting to complain on the long trips. looks like i need to get the sissy bar now instead of later. i have a dyna bob, and dont want to spend a ton. the dealer could be expensive. any suggestions would help. the only real stipulation is i need it to be tall enough to support a tail bag.
Old Jul 18, 2006 | 10:56 PM
bigmo_dynasb's Avatar
bigmo_dynasb
Default RE: need sissy bar help!
i got this one off of ebay for $25
when i bought it i wasnt for sure if it would fit...but its perfect...It measures 20.5" tall and 8-3/4" wide at the bottom part. Inside bottom measurements are 7-5/8.
Old Jul 18, 2006 | 11:15 PM
tb2377's Avatar
tb2377
got the detach sissybar. you get get different sizes, you can prabably install yourself
[IMG]local://upfiles/7785/005F762ABCFE433F8DD658F5C6432E5D.jpg[/IMG]
Old Jul 18, 2006 | 11:50 PM
Harleygirl81's Avatar
Harleygirl81
Glad I found someone talking about the sissy bar! My husband has the Street Bob also! Has anyone tried putting those side plates on that???????????? Oh my god!!!!!!!!!!!!! The bolt that holds the signal light on goes through the inside of the fender and when you "try" to take it out, it hits the tire. We finally figured a way to get it out, (not without of grunting and groaning and swearing). We had to let some air out of the tire. Got the damn sideplate put on and they gave us the wrong one!!!!!!!!!!!!!!!! We had to take it back off! The new ones should be arriving in a couple days and any suggestions on how to put those side plates on an easier way would be much appreciated!
Old Jul 18, 2006 | 11:54 PM
tb2377's Avatar
tb2377
i put mine on last summer, If i remember correctly you can jack the rear of the bike up so the rear tire hangs the bolt will clear. You don't have to lift the bike in so the tire is off the ground just enought to clear the bolt
Old Jul 19, 2006 | 12:09 AM
Harleygirl81
Thank you very much for that advise! Did you fasten the front of the bike down so it wouldn't tip over? We do have a trailer with the wheel chucks in it. Would you recommend fastening the front down so it doesn't tip over?
Old Jul 19, 2006 | 12:13 AM
voyager1's Avatar
voyager1
got to unbolt the dang shocks too. bike lift would help. pain in the ol' gulliver !!!!!!!!!!!!!!!
Old Jul 19, 2006 | 12:16 AM
tb2377's Avatar
tb2377
I didn't and i did't remove the shock either. you should probably fasten the front down, i took a stupid chance but it didn't fall and it all worked out ok. the bolt did touch the top of the tire but it came out and went in with no probems.
Old Jul 19, 2006 | 12:40 AM
bigmo_dynasb
i just had a buddy lift up on the fender and the bolts went right back in.....
i didnt take the shocks off either ...i also didnt tie the bike down ....did it in the gravel driveway...
propbaly wasnt a smart move ...
Old Jul 19, 2006 | 01:17 AM
WgSkee's Avatar
WgSkee
bigmo_dynasb.... Did mine the same way a little lift on the rearend they pulled right out.. Didn't use my jack.. Just go slow and easy..
