Removing baffles???
Old Jan 18, 2010 | 11:18 AM
JaronB's Avatar
JaronB
Originally Posted by rounder
good move on opening them up. for the most part taking the whole baffle out will effect your torque negatively. will certainly be loud though. I had to pull baffles to change em out of another set of pipes I had. 1 would not budge.... here's what I did..... stick pipe in freezer for 1/2 hour or so. Now, remove and heat the pipe with a blow dryer or heat gun from the outside, as the heat expands the outer pipe, the baffle will remain cold and will just fall right out(with some light tapping).
What he said, it's because HD baffles are press fit at the front of the pipe. My SE's were a PIA, but ended up getting a good deal on some V&H slip ons.
Old Feb 6, 2010 | 06:19 AM
srowton's Avatar
srowton
Runnng with Rush true duel pipes and mufflers with no baffles. Also have the vance and hines fuel pak. Runs load and great. Did I mention sounds great.
Old Feb 6, 2010 | 10:36 AM
cactusred's Avatar
cactusred
Generally in the past I just squirted some penetrating oil in the outlet of the pipe where the baffle meets the outer housing, let it soak for an hour, go do something else, come back squirt a little more and then couple light raps with the hammer and it falls right out. When you put it or some other baffle (bct baffs) back in it will smoke a little when it warms up but otherwise good to go.
KEYBEAR
Sep 6, 2013 04:06 PM
cgmartine
Jul 16, 2013 09:57 AM
JCleary
Touring Parts
Mar 23, 2012 10:39 PM
HDnAQHA
Nov 23, 2007 07:39 AM
TEK 679
Exhaust System Topics
13
Feb 19, 2007 10:23 PM
