07 street bob
Old Jan 17, 2010 | 10:10 PM
sage101's Avatar
sage101
Stage IV
Smile 07 street bob
Hello, Was wondering if anyone has any ideas on filling an extra hole on struts that was left when I relocated rear turn signal lights on a 07 street bob... Or do I just buy a strut cover? Thanks for any info out there...
Old Jan 17, 2010 | 10:26 PM
BluBob's Avatar
BluBob
I used the detachable docking points for a detach backrest. If you don't use a backrest, you may be able to use the filler caps anyway, but with a short allen-head instead of the long allen-head going through the docking point.
Old Jan 17, 2010 | 11:33 PM
sage101's Avatar
sage101
Stage IV
Thanks for the info... Don't have anything detachable but I'll try it.... Thanks again
Old Jan 17, 2010 | 11:45 PM
JaronB's Avatar
JaronB
For the detachable hardware kit you need the brackets that go in the inside of the fender so you can screw a bolt from the outside (it's threaded for front and back bolts). Since the bolt went from the inside of the fender and screwed into your turn sigs you didn't need threads. Or you can get shorter bolts (I think it's 3/8 x 16 thread) then get a spiked nuts and the spiked nut would just be on the outside of the strut and doesn't look like a normal nut. Then you just have to pay maybe less then $10 instead of spending $40 on the detachable hardware kit for the detachables you don't have.
Old Jan 18, 2010 | 04:28 AM
jmpancoast's Avatar
jmpancoast
Here is a pic of mine using the slugs from the relocation/detachable hardware kit. I also used chrome torx bolts.
prerender
Jun 6, 2022 12:12 AM
Stoffe
Jun 15, 2009 12:24 AM
gmc
May 11, 2009 10:59 AM
BluBob
Aug 20, 2008 09:25 PM
davidsdad
Aug 14, 2007 02:05 PM
