Improving brakes
Old Jan 18, 2010 | 08:04 PM
wholbein's Avatar
wholbein
Default Improving brakes
Soo I'm switching from a sport bike to my new Harley. With that said during my months of test riding I noticed that braking distance seems to be pretty long. Does anybody know of good performance brakes? Thanks guys
Old Jan 18, 2010 | 08:32 PM
ettenerf's Avatar
ettenerf
Stage IV
If you are willing to part with the bucks? "Brembo" I've heard are one of the very best. That is what I am going to put on my 2000 Road King.
Old Jan 18, 2010 | 10:10 PM
HDDyna2006's Avatar
HDDyna2006
Keep your distance, that have worked for me, new harleys come with Brembo's or upgrade to 4 piston calipers.
Old Jan 18, 2010 | 10:35 PM
JaronB's Avatar
JaronB
Really just give yourself more distance and you have to squeeze a lot harder then the rocket, plus double the weight. I've hit the brakes hard to check it out and you just gotta put more umph into it. You can also look at the dual disk set too! Not sure what needs to be done, but I know there is a thread out there.
Old Jan 18, 2010 | 11:47 PM
baldu's Avatar
baldu
What model are you considering? I haven't ridden most, but they're not all equal. The Wide Glide with the skinny wheel and a single front disc is not going to stop as well as the Fat Bob with the chubby front tire and twin discs up front.
Old Jan 19, 2010 | 02:53 AM
grbrown's Avatar
grbrown
If your bike doesn't have them stock, fit twin discs. If you get taken in by the single disc better than two, then tough! Braided hoses help, as can alternative pads.
If stock twin discs are still not enough there are alternative calipers out there. I went over the top with 13" discs and 6-pot calipers. They are adequate!
Old Jan 19, 2010 | 03:17 AM
XLCR4GM's Avatar
XLCR4GM
I agree with grbrown 100%. You can purchase aftermarket high friction brake pads and ceramic rotors or other high friction material rotors in either semi-floating or full-floating layouts and there are also multi-diameter, multi piston calipers from a number of makers like Nissin and Performance Machine as well as the Brembos that were already mentioned. Dual rotors also offer more surface area then a single rotor setup. So altogether there are quite a few choices out there for you to consider to help make your motorcycle slow down faster in a shorter distance. While upgrading your brake pads and brake rotors and brake calipers, don’t forget about upgrading your suspension too! Better rear shocks and better front forks will also help you to enjoy your road riding experience much more and although it won’t be the same as your sport bike it will be a much more enjoyable ride than the stock Harley ride will be. Good luck with you decisions and ride safe out there.
Old Jan 19, 2010 | 06:59 AM
tdshepard's Avatar
tdshepard
Unsubscribed From Forum
I put a Brembo caliper from a v-rod on my 06 superglide. Pretty cheap mod and stops great with one finger. Front end dive is the real problem with a stock bike, I have Racetech gold valve and springs in my forks.
Old Jan 19, 2010 | 08:02 AM
wholbein's Avatar
wholbein
Thanks guys! It seems like I have a lot to think about.
By the way, I just bought a '08 Street bob. I hope to have pictures up soon. She arrives Thursday or Friday!
Old Jan 19, 2010 | 08:05 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Pm calipers work well too, but I am sure the Brembo mod can be done less expensively. I also came from a sport bike background and it too quite a while to get used to stopping a heavier bike. It will never feel like a sport bike no matter what you try, at least that is my experience.
