Fuel Moto EFI Tuner
Old Jan 19, 2010 | 12:38 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by AFblacksheep
Jamie thanks for the information. I've read alot of good things about your company but I've seen very little information about this tuner. How did it come about?
The "Fuel Moto EFI Tuner by Dynojet" was released back in November. It is a Power Commander III that we market under the Fuel Moto brand which gives us flexibility and the opportunity of cross promotion. There is more info at http://fuelmotousa.com/fuelmotoefituner.htm
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 19, 2010 | 02:58 PM
US66harley's Avatar
US66harley
Have the Fuel Moto and 2" rush on my bike. No problems at all and was an easy install. It is the simpler version of the PC III that Jamie sends preprogrammed.
Old Jan 19, 2010 | 03:47 PM
AFblacksheep's Avatar
AFblacksheep
Thats good to here and with Fuel Moto (Jamie Long) reputation this seems like the best way top go. I dont know why someone would even consider the V/H Fuelpak when the FM tuner (PCIII) will do so much more and have the capability to cover all your upgrade needs with maps from Fuel Moto. Thanks for all the help this just seems like a no brainer now.
Old Jan 19, 2010 | 04:01 PM
blubyu2's Avatar
blubyu2
6th Gear
I would use a Thundermax Auto tune this is a stand alone ECM not a piggy back system to a stock ECM ,I was unsure of the Thundermax due to the cost,but what the heck I decided after trying every other one they made why not and I have a very much so modified 106 cu in motor and thus far this Thundermax has done all the work for me after the initial set up,,,Just look at what your buying and remember you get what ya pay for GOOD LUCK!!!!!
Old Jan 19, 2010 | 05:52 PM
ColdCase's Avatar
ColdCase
Actually, if you do some research over in the EFI forums you'll find the TTS tuning kit is currently the hot ticket for late model bikes (those with O2 sensors), from stock to extensively modified, the no brainer. Unless you want to sacrifice capability for simplicity, in which case the PCV with a dyno tune is probably best, followed by the PCV or PCIII with canned maps (all the inexpensive PCs disable the O2 sensor). The V&H fuel pack combined with the XiED works well. If the tuner has the software, the PCV dyno tune is relatively quick and inexpensive. The TTS is a better tuning system, however, and at $400 or so with no PITA install, its a no brainer. A year ago it wasn't so clear. In practice, the much more expensive auto tune systems aren't as good as the delphi EFI and don't provide as well a tune as the TTS... but then they can be easy to use. But do your research, if you care to. There is no one perfect system for everybody.
kwn36
May 11, 2015 06:59 PM
JefferiesHD1
Mar 3, 2013 09:18 PM
ryno62
May 25, 2012 02:51 AM
fuelmoto
Vendor For Sale Classifieds
Nov 10, 2009 12:21 PM
fuelmoto
Fuel Moto / Jackpot Mufflers
Nov 10, 2009 09:55 AM
