Taking the tins off any suggestions?
Old Jan 18, 2010 | 09:07 PM
cjm8806's Avatar
cjm8806
Default Taking the tins off any suggestions?
Going to take the tins off tomorrow any suggestion on draining the gas? i havent done it on my 07 SB yet and was wondering if anyone had any good techniques.
also while the tins are off i am chopping the rear fender and getting them painted. also going with burly slammer kit. any other suggestions (REASONABLE) while the bike is half apart?
Old Jan 19, 2010 | 02:54 AM
jmpancoast's Avatar
jmpancoast
Easiest way to drain the tank is to remove the top plate, then drain the tank using a cheap siphon pump. I pick up one like what is used to fill a kerosene heater from Home Depot. I was able to remove almost all the fuel this way and made no mess when I removed the crossover and the tank.
The removal of the fenders is pretty straight forward. I used painters tape to protect finished surfaces.
Here is a GREAT thread showing the removal of the guts from the tank.
https://www.hdforums.com/forum/dyna-...highlight=tank
Here is another post about fender chops.
https://www.hdforums.com/forum/dyna-...ml#post2536801
Old Jan 19, 2010 | 09:32 AM
panic_fan's Avatar
panic_fan
You can also put two pairs of vice-grips on the fuel cross-over and then cut the hose between them. Thread a bolt up each side to plug the hose and pull the tank. Then put it over a bucket and remove the plugs to drain the tank. Make sure your bucket is large enough to hold all the gas or your next post will be "Anyone have suggestions on cleaning up fuel spills?" Don't ask how I know...
Old Jan 19, 2010 | 10:41 AM
cjm8806's Avatar
cjm8806
haha thanks guys!
05Fatty
Dec 7, 2019 03:14 PM
Skeezmachine
Jun 22, 2011 12:40 AM
SpyderTB
Exhaust System Topics
Oct 27, 2009 09:18 AM
Sc07Sbob
Mar 3, 2008 11:26 AM
HERITAGEBOY
Feb 13, 2008 10:28 PM
