Rear brake won't light up brake light.
Old Jan 25, 2010 | 08:33 AM
trip20's Avatar
trip20
Question Rear brake won't light up brake light.
I have a friend with a '94 Wide Glide, and when depressing the rear brake pedal, the brake light will not light up.
Front brake does light up the tail light.
Does anyone know where the contact points are made with the rear brake so I can take a look?
Old Jan 25, 2010 | 09:16 AM
ackman1968's Avatar
ackman1968
Not sure on the early bikes but mine is in the rear brake hose by the master cylinder.
Old Jan 25, 2010 | 09:32 AM
trip20's Avatar
trip20
Crap it's inside the hose? So much for an easy fix. Thanks for the reply ackman.
Old Jan 25, 2010 | 02:57 PM
BigLowRider's Avatar
BigLowRider
Replace the stoplamp switch and bleed your brakes. $20 and 15 minutes. It don't get much better than that for a Harley repair!
Here's an example of how to test for this problem ...
https://www.hdforums.com/forum/gener...sportster.html
The switch is not located inside the hose, it is connected to the brake line. Look for a connector with two wires to your rear brake light.
BigLow
Old Jan 25, 2010 | 03:10 PM
trip20's Avatar
trip20
Yeah I suppose you're right BigLowRider. For some reason I thought it would be more involved than that. Thank you.
Old Jan 25, 2010 | 03:30 PM
SURFOR Chop's Avatar
SURFOR Chop
Your friend should probably test the connections going to the hydraulic pressure switch for the rear brake ... could be that there's a bad connection ....
While it is relatively inexpensive to replace the switch, if it is a wiring issue, replacing the switch won't fix it ... and, it is kind of a pain in the **** to replace the switch and bleed the brakes ....
Just another suggestion to try and avoid some aggravation if it's some corrosion on the spade lugs or a wire that's wearing out or something ... some sandpaper, a wire brush and some dielectric grease may solve his problem ....
R/
'Chop
Old Jan 25, 2010 | 03:33 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Before you change the brake switch I would advise to check if the wires comming from the switch do conduct all the way up to the stop lamp by using an ohm meter....
+ 1 on bleeding the brake line when you have to replace the switch kit!!
Here's a parts diagram (item # 164, BRAKE LIGHT SWITCH KIT, REAR, H-D p/n 72023-51D with p/n 9898 flag terminal, US$ 15,48 at LSHD1.com)
FXD2003Rider
Old Jan 25, 2010 | 03:41 PM
jackyl's Avatar
jackyl
i had the same problem last year, the running light was on but when i hit the brake nothing. i found out that the bulb is a dual fillment bulb, one of the fillments are broken. all you need to do is just buy a new bulb and you are back in business. my bad just read the rest of the posts, yes its the button or plunger switch dooo hicky jackyl
Old Jan 25, 2010 | 03:51 PM
trip20's Avatar
trip20
Thanks fellas!......
You're right though jackyl.... we should start with the cheap stuff and work our way up. I've got some spare bulbs at home I'll bring one along when i stop by his place tonight.
SURFER Chop & FXD2003Rider -- thanks for the info and diagram it'll definitely help. I'll be sure to bleed the brakes.
Old Jan 25, 2010 | 04:15 PM
trip20's Avatar
trip20
jackyl I just remembered the front brake engages the brake light so I think the filament is ok
