Anyone using the 6" pullback risers on a fatbob?
Old Jan 28, 2010 | 05:09 PM
thirdjld's Avatar
thirdjld
Default Anyone using the 6" pullback risers on a fatbob?
If anyone is using the 6" pullback risers on their fatbob did you have to change any cables? It's part of the plan for winter mods, Thanks
Hoss
Old Jan 28, 2010 | 10:58 PM
gixxer6285's Avatar
gixxer6285
6th Gear
Anyone using the 6" pullback risers on a fatbob?-100_0190.jpgI went with 8 inch straight risers and just had to relocate the clutch cable. Everything else had enough slack.
Old Jan 29, 2010 | 04:02 PM
we_brown's Avatar
we_brown
I added the 6" pull back risers to my 08 FXDF. No cable change required. Much better riding position. My writst were sore after a long ride, now no problems. Great add on.
Old Jan 29, 2010 | 04:16 PM
thirdjld's Avatar
thirdjld
Thanks for the info. It's moving from plan to do.
Hoss
Old Jan 29, 2010 | 08:21 PM
Centerline's Avatar
Centerline
Yes I am. Stock cables work fine.....
Old Sep 21, 2022 | 10:30 PM
D-Rob's Avatar
D-Rob
Stage I
[QUOTE=Centerline;6171110]Yes I am. Stock cables work fine.....
Nice bike! Did you have any problems with signal clearance of the tank with these? HD shop there would be an issue on FXDF with this?
press, lean, and roll
Jul 17, 2017 12:03 AM
legionxxii
Aug 23, 2015 07:23 PM
roadkingkat
May 15, 2012 07:36 AM
pewter sb
Apr 17, 2011 04:14 PM
capnjim01
Sep 30, 2006 11:29 PM
