installing chrome lower fork tubes
Old Feb 20, 2010 | 07:45 PM
QuickSilver74's Avatar
QuickSilver74
Default installing chrome lower fork tubes
anyone have a write up on this? i searched but couldnt find any info.
is this something i can tackle at home or should i pay to have it done?
Old Feb 20, 2010 | 08:17 PM
96 Wide Glide's Avatar
96 Wide Glide
No, it's easy. If you have a manual and a large cresent wrench (or the proper size box end for the top bolt), you can do it. Get a length of proper size pvc tube to use as a seal driver, and put the old seal over top of the new one, so the old seal takes all the punishment.
When your putting it back together, rather than using one hand to compress the spring and get the top cap threads started, tighten the top cap in the upper tree, then you have two hands to push up the fork and get the threads started.
Make sure the lettering/ numbers on the new seals are facing up.
IrishHick1776
Jan 28, 2019 02:29 PM
Livet
Apr 6, 2014 05:03 PM
Beachman
Apr 19, 2010 02:58 PM
jcmusic
May 25, 2009 05:17 PM
mopar7
Nov 17, 2007 05:53 PM
