Forwards
Old Feb 22, 2010 | 11:27 AM
Tuggin's Avatar
Tuggin
Default Forwards
I read on the Gen. Dis. Forum that someone on the Dyna Forum fabricated some brackets to move forward controls back a little. I did a search but did'nt come up with the thread Any help would be appreciated.
TOM
Old Feb 22, 2010 | 02:50 PM
fhansen's Avatar
fhansen
There've been some threads on this subject although I can't remember where. I made some adaptor plates myself that set the forwards back a full 2". J&P Cycles show some "Kick-Back" plates on pg 812 of their 2010 catalog that set the controls back 1 3/8".
Old Feb 22, 2010 | 03:59 PM
ghostrider69's Avatar
ghostrider69
fhansen, I would like to see some pics of those brackets that move the controls back 2". I can't imagine the stock forward controls coming back 2" without being moved to the top or outside of the primary.
Tuggin, are you talking about these brackets that moved the controls back 1 1/4"?
Old Feb 22, 2010 | 04:05 PM
Tuggin's Avatar
Tuggin
Could be Ghostrider, where did they come from?
Old Feb 22, 2010 | 04:16 PM
ghostrider69
I made them.
Old Feb 22, 2010 | 06:20 PM
fhansen's Avatar
fhansen
It took some doin. The shift lever pivot ended up quite close to the primary. I had to go with a longer shift rod-15", I believe- to rotate the inner shift lever away from the primary and I still had to cope the lever for clearance. The brake side was no problem other than shortening the rod. I'll get some pics.
Old Feb 22, 2010 | 07:54 PM
fhansen's Avatar
fhansen
OK, here's the pics, such as they are. A shift lever could be found or fabricated without the rearward bend of the WG's lever but this worked out:
Old Feb 23, 2010 | 11:19 PM
JimmieJack's Avatar
JimmieJack
I took the idea from Ghostrider and made some too but I only got about an 1-1/4 set back. I also had to run the threads up on the brake rod.
Attached Thumbnails Forwards-stock-plate-1.jpg   Forwards-forwards-030.jpg   Forwards-cut-and-shape.jpg   Forwards-rethreaded-rod.jpg   Forwards-forwards-028.jpg
Old Mar 24, 2010 | 02:31 PM
Glydiator's Avatar
Glydiator
if i make a set of these I think i will add heel rests built on to the plates. or at least have a hole to mount some pegs of some kind for heel rests.
Old Mar 24, 2010 | 04:34 PM
ambrose's Avatar
ambrose
So by moving them back that extra 1" and a bit, did it make a difference?
More comfortable?
