So I have my wheel on the way to me (Thanks again JCK!) and I am in need of a tire. I have a SE180 on the rear and it would be nice to match that compound as close to possible.
I'm pretty sure they make the Avon Venom in the 21-90-90 size, is this a close match? Recommendations? Once my rear tire is done, I plan to have matching tires put on front/rear....but for now, I want to throw on the new wheel.
The issue is the Wide Glide hub is about 1.25 wider from center to rotor mount, so you won't be able to align the rotor in a standard Dyna front end.
When i went to a std Dyna wheel on my WG, i used a spacer to GAIN that distance to the rotor mount. So no, jmp is correct, it won't work for you, unless you have a WG front end.
