Rear pulley tech ?
Old Feb 26, 2010 | 08:45 AM
OutlawBagger's Avatar
OutlawBagger
Default Rear pulley tech ?
I just got a DNA Super Spoke rear pulley. I'm gonna put it on a factory spoke wheel. Does anyone know what size spacer I'm gonna need. I have done a search and didn't find much for a factory wheel.
Also I'm going from the factory 66t to a 70t. Do you think that will make much difference? I know I will prob loose a little top end. Do you think I'll run into any other problems?
Old Feb 26, 2010 | 09:10 AM
8541hog's Avatar
8541hog
You may want to look at the belt to see if you need a different one, not sure but I believe you will need to change it to one with different (more or less) teeth. Someone else may know better on that.
Old Feb 26, 2010 | 11:24 AM
thedonthere's Avatar
thedonthere
The width is where you may have a problem. When I went from my stock pulley to a SE 70 tooth I had to change belts. My original was 1.125" X 132 and the SE is 1.0" X 131.The 1" belt is PN 40046-07
Old Feb 26, 2010 | 11:50 AM
paul s's Avatar
paul s
Hey Don, Do you have a number for the 70T pulley? I'm ready to go lower.
Old Feb 26, 2010 | 03:45 PM
FUQUA's Avatar
FUQUA
I'm runnin the exact pulley....i dont know what the stock tooth count was. (Should be the same as your's both 6-speed)
But the only thing i needed was a spacer Size.940" part #1201-0102
Through Parts Unlimited....but you should be able to use that same part#
with Drag Specialties.....You should not need a belt change!!!!!!!!!!!!
Old Feb 26, 2010 | 06:53 PM
OutlawBagger
Well I tried it out today. Took the wheel off and put the new pulley on just for mock up. It's not gonna work. The belt isn't long enough to get any adjustment. Oh well looks like I'll have a pulley and rotors for sale. FUQUA stock 09 tooth count is 66t.
Old Feb 26, 2010 | 07:20 PM
8541hog's Avatar
8541hog
Ummmm.... hmmm...
Old Feb 26, 2010 | 07:34 PM
OutlawBagger
Originally Posted by 8541hog
Ummmm.... hmmm...
YEA YEA LOL. I just thought I would try.
Old Feb 26, 2010 | 07:38 PM
8541hog's Avatar
8541hog
Isn't owning a Harley fun.... Ride safe Bro, good luck with the mod
Old Feb 26, 2010 | 08:05 PM
FUQUA's Avatar
FUQUA
Im at a loss......i thought they were identical. Im missing something here. Im gonna call tomorrow and see what tooth mine was.
That Sux!!!!!!!!!!!!!!
