Lowered Fat Bob
Old Feb 28, 2010 | 07:16 AM
russell6hp's Avatar
russell6hp
Default Lowered Fat Bob
Put Progressive Drop-In springs in the front and Burly shocks on the rear. Whole install took 90 minutes (faster if I wasn't taking the pics or having to run back to the fridge).
I wanted to get a Slammer Kit, but was told Burly doesn't offer the front springs for an FXDF, however Progressive did. I suspect that these two companies are actually one in the same, especially after looking at the packaging.
Cost of the kit was under $300 (local dealer is doing 20% off aftermarket parts) and quite frankly the hardest part was getting the bike up onto the jack.
Two words of warning - this lowers the bike so much that in order to put it back up onto a jack you will need to drive up onto something a bit higher. I used two 3/4 plywood boards. Also, the lean angle when on the kickstand has been reduced to where it almost sits straight up! I am working on this issue. I wonder if a Sporty kickstand would fit?
The first pic is a before, everything else is after.
Attached Thumbnails Lowered Fat Bob-before.jpg   Lowered Fat Bob-after.jpg   Lowered Fat Bob-rear.jpg   Lowered Fat Bob-shocks.jpg   Lowered Fat Bob-springs.jpg
Old Feb 28, 2010 | 07:32 AM
Torn's Avatar
Torn
Looks good russ make sure your rear fender dosnt bottom out. The wires for your tail light run right threw the middle of it.
Old Feb 28, 2010 | 08:51 AM
rounder's Avatar
rounder
you can notch out your current kickstand to have it lean a little more.
Old Feb 28, 2010 | 09:05 AM
TinySAV's Avatar
TinySAV
Looks real good bro. keep us up to date with the kick stand and the fender
Old Feb 28, 2010 | 10:07 AM
russell6hp's Avatar
russell6hp
Rounder,
Not sure what you mean by notching. Could you clarify? I stiffened the shocks all the way, and there is about an inch of clearance without me sitting on it. When I get on, the shocks barely compress. Plus I've had no issues on my test runs. Haven't put the girl on it yet, but hell, she ain't that big!
Old Feb 28, 2010 | 10:53 AM
08fxdf43202's Avatar
08fxdf43202
Originally Posted by russell6hp
Rounder,
Remove the jiffy stand from the bike.
Sand off a little material from the top of the 'lock' tab.
Reinstall the jiffy stand.
Old Feb 28, 2010 | 11:14 AM
thedonthere's Avatar
thedonthere
+1 I did this. You have to grind a little (1/4"-5/16" max) off the tab that contacts the frame.
Old Feb 28, 2010 | 11:22 AM
JimmieJack's Avatar
JimmieJack
Looks real good. Especially Photo #2. Looks like you took off the engine guard / highway bars too - think it looks "tighter" without.
I've been thinking of lowering my St.Bob - I'm still not sure about lowering blocks vs. shorter shocks. I think I can get 11" progressive 412 and the progressive front drop-ins for about the same price as the Burly Kit.
Please, give an update on your impression of how it rides / handles.
Old Feb 28, 2010 | 01:34 PM
mikel61101's Avatar
mikel61101
If you want it to lean more when your off it just put the engine guard back on and dont use the kickstand...
Old Feb 28, 2010 | 03:04 PM
EricInNCa's Avatar
EricInNCa
Yeah, I'd be real interested in the ride quality and ground clearance. Let us all know...
