shift shaft seal leaking problem
Old Mar 15, 2010 | 08:01 PM
tully_mars's Avatar
tully_mars
Default shift shaft seal leaking problem
Ok, this has been a really rough problem to figure out. 4 months after buying my 06 Dyna Low Rider, the shift seal is leaking. Get it replaced. A few months later the 5th gear seal starts leaking. Get it replaced. Upgrade the controls to forward controls. 100 miles later leaks again. Suspicious of inner primary since it was just replaced due to install of controls. Replaced, then 200 miles later leak again. Shift shaft seal torn and replaced. Drive 100 more miles leaking again. What gives? Missing something here that is messing up these inner seals.
When in neutral I don't hear any noise between the clutch in and out so IPB is assumed to be ok.
suggestions? Dealer not making much headway but at least they are standing behind the issues.
Thanks,
HAD20
2014-2024 Touring Models
May 29, 2018 11:01 AM
rgregory
Apr 15, 2018 10:10 AM
Kaycee
Apr 30, 2013 06:49 PM
DBLJ
EVO
Jun 5, 2011 06:53 PM
splitting_lanes
May 27, 2008 08:52 AM
