Feul pump keeps running
Old Mar 19, 2010 | 06:50 AM
jasonyankees's Avatar
jasonyankees
Default Feul pump keeps running
My bro's 05 wideglide got wet in the storm last week. Up to the lower muffler. Now when u turn the ignition on, the fuel pump runs contiuoulsy ( proper spelling optional) . Anyone ever seen this before ? We think there is a short somewhere , looking for suggestions if anyone can help.
Thanks
Old Mar 19, 2010 | 07:02 AM
jmpancoast's Avatar
jmpancoast
I would start by unplugging the ECM and any fuel management units. See if the connectors are wet. Put some di-electric grease on the terminals.
Maybe wet relays in the electrical panel?
Old Mar 19, 2010 | 08:29 AM
8541hog's Avatar
8541hog
jmp is correct, start at the bottom of the bike and work your way up looking for any electrical connector, open them and make sure they are dry.
Is anything else acting abnormal? All lights still work? Does it run?
Old Mar 19, 2010 | 08:51 AM
Baeseman1's Avatar
Baeseman1
I'd remove the seat/fuse panel cover so everything could dry out for a few days in addition to the above advice.
Was it in a garage that flooded or parked outside in the elements?
Old Mar 19, 2010 | 09:34 AM
CRZYLGZZ's Avatar
CRZYLGZZ
Happened to me, but when i washed it. my ECM connector just got flooded with water, and caused my ride to do all sorts of crazy things, at one point i thought it was doing the Macarena. I disconnected the ECM , WD-40'd the contacts, used a brush to wipe away and debris, put that funky di electric grease, put her together and Boom, she was good to go.
Old May 30, 2015 | 12:27 PM
bbyboy299's Avatar
bbyboy299
Default Fuel pump constantly running bike not started
Dis you ever figure out what happened. My wifes just started doing this last week and i am out if ideas
Old May 30, 2015 | 02:23 PM
SIDECAR BOB's Avatar
SIDECAR BOB
fuel pump relay may have gone bad and "stuck"closed
00copglide
Oct 21, 2017 04:12 AM
Rambo_1mo
Electrical/Lighting/Alarm
11
Dec 24, 2016 09:18 AM
just plain john
Aug 28, 2013 09:08 PM
jpeirens
Jun 13, 2013 07:13 AM
ramu3527
Aug 13, 2012 08:41 PM
